A8 auto trans stuck in park
Old Jul 21, 2023 | 09:57 AM
shaark92's Avatar
shaark92
Default A8 auto trans stuck in park
Moved vette to 2 post lift to r/r brake pads.
Have to push it the last 3-4 feet (door at lift post)
nanny howling about “shift to park”. Ok. Apparently have to restart.
with all doors closed. So now im in park and cant shift out of park.
i hate the nannies on this thing.
appreciate help
Old Jul 21, 2023 | 10:02 AM
shaark92's Avatar
shaark92
Well… i went back to ground zero … and now it works.
idk. Doesnt inspire confidence.
There has GOT to be a way to engage “maintenance mode” where i can shift N To P without cranking … and … door open without the bawling.
cmon.
Old Jul 21, 2023 | 12:30 PM
GOLD72's Avatar
GOLD72
cmon.
Gotta love the engineers and the lawyers trying to protect themselves from us!!
Old Jul 21, 2023 | 03:41 PM
DTOM's Avatar
DTOM
C7 of Year Finalist (performance mods) 2019
cmon.
Hold the start button for 10 seconds without putting your foot on the brake.
Old Jul 21, 2023 | 06:51 PM
shaark92's Avatar
shaark92
I did discover how fragile that shifter is ... ALL plastic under that shifter ****. A bit disappointed ,,, and a word to the wise should be sufficient.
I've done the "start button" w/o brake ... all I've gotten is powered electronics ... it doesn't allow me to manipulate the transmission shifter without the engine's running, nor did it "shut up" the door chime.
got the pads/rotors changed (frozen rotors) ... so in "burnishing" I wanted to avoid that pocket burn of holding hot pads on a hot rotor by using the park brake/neutral. "Veronica" allowed that ... but then she required I step on the brake pedal again to release the park brake. Good grief.
I'm still not sure what caused the shifter lock ... nor what specific corrective action I took.
Old Jul 22, 2023 | 12:12 PM
Obe1 GS's Avatar
Obe1 GS
My shifter moves freely after holding the start button for 10 seconds without applying the brake.
Old Jul 22, 2023 | 01:20 PM
ErnieN85's Avatar
ErnieN85
Mine doesn’t
To A8 auto trans stuck in park
