Shift Rod Question...
Old Aug 22, 2023 | 06:39 PM
boraxman's Avatar
boraxman
Default Shift Rod Question...
I can't remember how the rod looked on the stock shifter... the rod is now flush where the line is but does it need to slide back more where it's circled or do I have it right? Thanks!
Old Aug 22, 2023 | 10:41 PM
boraxman's Avatar
boraxman
I think I'm good, looks like rod is notched for the bolt to thread down...
Old Aug 22, 2023 | 11:01 PM
CatCity's Avatar
CatCity
Not sure this view helps but here's a look at mine when I replaced shifter with MGW. This is view prior to install, so it's the factory setting.
Good luck -
Old Aug 22, 2023 | 11:05 PM
boraxman's Avatar
boraxman
^^^^^Thanks.. I was just looking at the sticky above showing how to install a Mgw shifter and judging by the pictures in that thread It looks identical so all good.
​​​​​​Maybe this thread will help someone down the road.
To Shift Rod Question...
