C7 Battery replacement problems
Old Aug 23, 2023 | 08:42 PM
Charli66's Avatar
Charli66
5th Gear
Default C7 Battery replacement problems
Replacing my 2016 Stingray battery seemed pretty straightforward, but after installing the new battery I have lost nearly all electronics. Doors will not open, car won't start, dashboard is dark, etc. Also, taillights and front driving lights are on. Key FOB has new battery. Anyone ever experience something like this. Thanks.
Old Aug 23, 2023 | 09:22 PM
AZRenegade's Avatar
AZRenegade
Search for videos on how to change a C7 battery. I think you will discover that you probably didn't hook up the battery correctly. A video is worth a thousand posted well meaning opinions.
Old Aug 23, 2023 | 09:26 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
This,
Check your connections. Make sure they are as they were aligned from the factory and tight. If you're sure of the connections, check the 350a fuse to see if it's blown.
Elmer
Old Aug 23, 2023 | 11:10 PM
Charli66's Avatar
Charli66
5th Gear
Thanks!
Old Aug 23, 2023 | 11:11 PM
Charli66's Avatar
Charli66
5th Gear
Thanks. Are you referring to the 350A fuse that is part of the positive connection?
Old Aug 24, 2023 | 02:10 AM
Pktrusty's Avatar
Pktrusty
Yes
Old Aug 24, 2023 | 07:17 AM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Old Aug 24, 2023 | 09:40 AM
Maxpowers's Avatar
Maxpowers
Check the little black wire is attached.
Old Aug 27, 2023 | 08:34 AM
Zjoe6's Avatar
Zjoe6
with all the above. It might seem that a nut is tight and yet the connector is not fully seated causing a bad electrical connection. It may pass a low current to keep some instruments on but not a starting load....and all sorts of other weird possibilities.
Old Aug 27, 2023 | 09:40 AM
Racer1735's Avatar
Racer1735
As mentioned, check that the little black wire on the ground strap is still intact. Also, that power fuse block (the red handle) is a bear to get seated properly and the 13mm nut seated correctly. If that's not on properly you can have all kinds of gremlins (such as you describe). Remember to disconnect your ground cable when you go to fiddle with the power fuse.
Old Aug 27, 2023 | 02:16 PM
Charli66's Avatar
Charli66
5th Gear
Thanks. It turns out that was exactly the problem. It looked and felt tight, but wasn't tight enough. All the best.
Old Sep 1, 2023 | 02:31 PM
sbrundrett's Avatar
sbrundrett
3rd Gear
I am having the same thing with my 2015. Just had to replace battery when the car would not start after being gone a week. I have checked all connections several times and have installed two new batteries thinking the first one might have been bad. It was from a chevy dealer who tried to sell me a new battery with corrosion on the terminals (I didn't accept that one). Let me if you have success and what you finally did to start the car.
Scott
Old Sep 1, 2023 | 06:23 PM
Charli66's Avatar
Charli66
5th Gear
Scott. In my case, the issue turned out that I had no tightened all the connections sufficiently. They felt tight and I was cautious to not strip any threads, but apparently they were not tight enough. I disconnected both terminals and the separate red wire; cleaned everything with a wire brush then torqued down all the connections hard when I reconnected. It has worked well since. Good luck on yours. John
Old Sep 3, 2023 | 12:16 PM
sbrundrett's Avatar
sbrundrett
3rd Gear
I finely got the car started. That positive terminal connection is super sensitive. I reconnected it carefully at least 5 times before I got it right.
Thanks for all the help. So grateful I didn't have to tow the dead car
To C7 Battery replacement problems
