CCB brake question
Old Sep 4, 2023 | 03:34 PM
TKOGTO's Avatar
TKOGTO
Default CCB brake question
Can you run “normal” brake pads with CCB rotors or do you need to use pads made for CCB’s?
TIA
Old Sep 4, 2023 | 03:54 PM
Maxpowers's Avatar
Maxpowers
CCB requires a pad compound designed for it.
Old Sep 4, 2023 | 04:04 PM
Bill Dearborn's Avatar
Bill Dearborn
The front pads are made by Pagid for Brembo. The Pagid brake pads are supposedly made for CCM rotors. The Pagid track pads are shown as being specifically made for CCM rotors.
Track Pads:
Bill
Old Sep 6, 2023 | 05:07 PM
TKOGTO's Avatar
TKOGTO
Thanks guys.
Was @ WGI and started to get brake fade in 3rd session of day 1. To my surprise, the left front pads had worn down past the point I normally replace them and I concluded that was cooking the fluid. Lazily, I did not check them beforehand as I had only 5 days on them. In the past, the stock CCB pads lasted at least 7 days with perhaps a day/day and a half still possible. A buddy had some Carbotech XP-10s he was willing to part with but with neither sure they would work with the CCB rotors and no vendors open for Labor Day, I started the post.
Got lucky in the end when 89xMotorsports had a spare set. Lesson learned. Rotate pads every 2 days for more even wear and bring the back up set regardless.
Thanks again.
Old Apr 27, 2024 | 07:23 PM
flynhi's Avatar
flynhi
Are these available thru GM or must I go to Brembo/ Pagid?
Old Apr 29, 2024 | 07:08 PM
SouthernSon's Avatar
SouthernSon
Just make sure they have the higher copper content as the OEM pads.
Old Apr 30, 2024 | 08:16 AM
argonaut's Avatar
argonaut
Here are my notes on OEM CCB pads for 2017 GS Z07. Prices have probably changed.
  • Front pads:
    • AC Delco: OEM Brake Pad Part Number: GM part no: 23316708, ACDelco part# 171-1186
    • Pagid No 8091. Compounds:
  • Rear pads
    • GM OEM pads:
      • AC Delco 171-1143 (OEM part Number 23198750) Brembo part number: 07977062200
        $684 on Amazon.
To CCB brake question
