Soler Throttle body/controller work with Range device?
Old Sep 10, 2023 | 01:45 PM
Wujekcity's Avatar
Wujekcity
Default Soler Throttle body/controller work with Range device?
Currently using afm range device and Tuesday getting Soler TB and controller installed. Will all 3 work together? Or do I need to unplug the range device?
ty for your advice in advance!!
Old Sep 10, 2023 | 05:16 PM
Buddhaman's Avatar
Buddhaman
They will all work together. I have the range and the controller right now with no issues.
Old Sep 10, 2023 | 05:56 PM
aklim's Avatar
aklim
I don't know why not. As long as they manipulate the data to the ECM and it isn't the same data, it should.
Old Sep 11, 2023 | 10:05 PM
buckeye4's Avatar
buckeye4
Same here, no issues.
Old Sep 13, 2023 | 09:21 PM
Wickdc7's Avatar
Wickdc7
All 3 work together, 3 years now with zero issues.
Old Sep 14, 2023 | 04:09 AM
Wujekcity's Avatar
Wujekcity
I've had the car less than 24 hrs since install. Holy crap!!!! What a unreal mod!!! Just insane!! Yes we different modes already built in, but this is wild!!!
Old Sep 14, 2023 | 07:55 AM
guido7834's Avatar
guido7834
I've had the Soler throttle controller for a few years now. 3 Times it's caused problems putting the car in reduced power mode, (throttle position sensor code) where I had to unhook it. I'm about ready to remove it...
Old Sep 14, 2023 | 08:09 AM
aklim's Avatar
aklim
Check with Diablew and see if you can return it if you don't like it. If you can, do try the Diablo I3 and see if it does the same thing as the Soler throttle controller WITHOUT the hiccups. You are a good candidate.
Old Sep 14, 2023 | 02:14 PM
Wujekcity's Avatar
Wujekcity
sorry you had that experience!!! u have just the controller? or u bought the TB as well?
Old Sep 20, 2023 | 02:27 PM
Double's Avatar
Double
I was considering doing just the TB, do you need to do the controller as well? I have an M7.
Old Sep 20, 2023 | 03:09 PM
aklim's Avatar
aklim
I believe tuning can increase the tip in so you don't need either. $600 or less. Not a good idea if you have any warranty.
Old Sep 20, 2023 | 04:52 PM
Wickdc7's Avatar
Wickdc7
you can just do the TB. increases air flow.
Old Sep 20, 2023 | 06:02 PM
aklim's Avatar
aklim
Nice, is that the bottleneck to the system?
To Soler Throttle body/controller work with Range device?
