Backup camera calibration?
Old Sep 12, 2023 | 01:57 AM
Pktrusty's Avatar
Pktrusty
Default Backup camera calibration?
I just recently did work to my car which included pulling out the motor. Now, when I put the car in reverse, the back up lines are off with the steering wheel. Is this because I was off on attaching the steering shaft to the steering rack? My car was out of service for almost a year while stuff got together and I had family come over. Kids like to touch stuff and of course they touched the steering rack.
Can I just recalibrate the lines? Are those based off steering wheel feedback or something on the rack?
Old Sep 12, 2023 | 10:51 AM
squirrelchew's Avatar
squirrelchew
if SAS self-calibration (fully turn left-right-left) doesn't fix it, you're likely gonna need tooling or a shop visit to calibrate it.
Old Sep 14, 2023 | 08:39 PM
Dcasole's Avatar
Dcasole
Your steering wheel position sensor is off, but worse is your clock spring could be in wrong position also . This will also cause stability control issues ...
Is the car tracking straight when u hold the steering wheel straight?
Dave
Old Sep 14, 2023 | 08:51 PM
Pktrusty's Avatar
Pktrusty
Car tracks fine when wheel is straight. The only way I noticed something was off was when I put it in reverse.
Old Sep 14, 2023 | 08:59 PM
Dcasole's Avatar
Dcasole
Then you need to calibrate the steering wheel sensor with GDS2 or similar scan tool
Dave
Old Sep 15, 2023 | 12:36 AM
abflyboy's Avatar
abflyboy
Grid lines in back up camera image are derived from steering wheel position sensor input.
Get that calibrated and you should be good to go. Provided there aren't other problems.
Old Sep 17, 2023 | 10:37 PM
Pktrusty's Avatar
Pktrusty
Any idea what a decent price on a calibration?
Old Sep 18, 2023 | 10:14 AM
Dcasole's Avatar
Dcasole
Not a clue but I can't believe it would be anything more than a 1 hour charge to calaibrate . I think it took me all of 5 minutes to check mine after i did my C7 header install . I also swapped out a steering column to a powered tilt unit on my C6 , again it took no longer that 5 minutes to run the process
Any competent repair shop will have a scan tool capable of calaibrating a steering wheel postion sensor as the corvette is not the only car that has one
Dave
To Backup camera calibration?
