Front frame rail welding
my name is Daniel from northern Germany. I own a C7 Z06 with a front damage. I checked the main frame and all looks fine and ready to weld the front extention rails to the impact bar and main frame.
In the attached photo you can see one bar already sticking in the main frame. Question is: how to measure, align the rails? In the manual I could only find the number 886,85mm from bold to bold within the rails, but nothing about how deep to put them into the main frame. Until the inner stop of the main frame? Are there more numbers for measuring and control?
Kind regards,
Daniel
Contact the guy ("Luke42_02") who rebuilt the C7, maybe he has some info.
There can be a bit of trouble if the “hole” the new part goes in is a little wallowed out and there is some play. In that case, I would still push it in until it hits the back of the compartment then I would adjust it slightly (up, down, left, right, but not in/out) to the best of my ability and make sure it’s level with the other side. Remember, the floor of your garage is probably not level, so account for that. There would only be a few millimeters of play if that were the case and I’m fairly confident the body panels have enough adjustment that you can adjust it out if you get the angle slightly wrong. As long as the main frame is not bent, hitting the back of that compartment is probably your best guide as far as getting it in there straight.
There was a point in my second rebuild that I had convinced myself I had blown the angle on one of the frame horns by 1-2 degrees and needed to grind the thing down and start over. I was so angry and literally screaming profanity in my garage at 2am. My dad took a look at it the next day eyeballed it, and said “if it’s off, it’s not off by much, I’d just go with it.” I did and the whole car came together beautifully. It helps to have an experienced hand to look things over if you’re getting a little neurotic and trying to make everything too perfect.
If you ever need me, you can reach me at Lukerecords at gmail.com. Or call me at 316 304 2911. If I don’t answer, send another one.
Remember, I’m just an amateur working my way through things the same way you are, so take my advice at your own risk.
PS, This is a very nice feature of the C7 Corvette. The current gen Suburban is not like this and you have to guess how far in/out to weld the frame horn and it’s a terrible pain. The C7 is the easiest to rebuild of all modern cars that I have ever tried, almost like they designed it to be easy to rebuild.
Thanks for watching the channel. If you haven’t found it yet, there is a video on there regarding welding these frame horns.
The GM repair manual makes reference to some sort of laser spatial positioning system that you use to make sure it’s positioned correctly, but I’m sure that costs even more than a frame rack.
thank you for your infos. I think after two full restaurations (68 Mustang and 79 Trans Am), 20 years in metal work and a few welding certificates I can estimate a good weldseam from a bad one. Working with 3D lasers and building racks with marked "zerolines" is not a problem. It is more the fact, that I can not find too much measurements for the car for alignment. Also the professionals needs this numbers to align the cars.
Greetings...Daniel
P.s. here in Germany is only one real specialist for Corvettes. A few GM dealers also send their cars to this workshop. But he is more then 500 miles away. He would be the only one next to me who I trust to do this. So I will try it by myself. Last cars all got the note "A" in surveys and insurance inspections. Time will solve all problems. And the other benefit: additional wisom with every project:-)
we went through a similar process replacing the windshield frame on my C7. Clamped things in place. Installed the removable roof panel, front fender and entire door. You only get one shot with the adhesive on the windshield frame. It’s not welded.
