Trans cooler base car
Old Nov 22, 2023 | 11:50 AM
Rhettvette's Avatar
Rhettvette
Default Trans cooler base car
Hello, I took the trans cooler off some time back on a build and forgot where the small black attached module with fins goes
the wire harness plugs into it, and Is attached to the cooling fan via small wire harness and I guess it's a temperature monitor to turn on the fan.
any help would help. I looked on the web pictures of the cooler but I could not see any pictures of the small attachment.
Thank you
Old Nov 23, 2023 | 09:00 AM
69 L46 4 Speed's Avatar
69 L46 4 Speed
It mounts behind the left quarter panel.
Old Nov 23, 2023 | 09:01 PM
Bill Dearborn's Avatar
Bill Dearborn
Not sure what your question is but this picture shows the transmission cooler mounted behind the left-side rear fascia just after the fascia was forcibly removed by a tire wall.
Bill
Old Nov 24, 2023 | 09:30 AM
Rhettvette's Avatar
Rhettvette
Default Sensor mount
Thank you to the replies. I found where it mounts to the cooler through the dealership.
To Trans cooler base car
