Advice on trouble codes (DTC)
I'm looking to buy a used Z06 from a dealer on the other coast from me. I had LemonSquad inspect the car, and they reported reading some trouble codes. I lack the experience to know how to interpret what they found. If anyone does have some experience with these kinds of issues, your help would be appreciated.
Thanks,
-Nick
This is the one that concerns me the most:
B2745:02 - Traction control switch circuit short to ground
DTC history status : History
Since DTC clear : Passed and failed
Last test : Passed
This ignition cycle : Passed
MIL status : Not requested
I'm pretty sure this is just a key fob battery issue:
B3110:00 - Keyless entry transmitter 2 battery
Last test : Passed
This ignition cycle : Passed and failed
This one was further diagnosed as a blend door actuator failure, and is being fixed by the dealer:
B374A:61 Air flow control feedback circuit stuck
DTC current status : Current
The rest all show as "not current," which I don't really know how to interpret. Could these really be transient issues, maybe caused by a low battery, or jump start, or ...?
B1325:03 - Control module power circuit low voltage
DTC current status : Not current
B3124:05 - Keyless entry antenna 6 high voltage/open
B1325:07 - Control module power circuit high voltage
Thanks,
-Nick
Last test : Passed
Last test : Passed
The key fob issue could very well be a key fob battery that needs to be replaced.
The traction control switch (**** on the console) issue could also be due to a low car battery. The last test indicates it isn't failing anymore and if it isn't broken it is hard to fix. Whatever the dealer did to correct the other three failures probably resolved this one as well. The BCM monitors the traction control switch positions and if its supply voltage is on the low side that could lead to BCM read errors.
Bill
-Nick
