Inovators West Balancer install question
Old Dec 9, 2023 | 03:33 PM
deepsouthtech's Avatar
deepsouthtech
Default Inovators West Balancer install question
C7 Z06 18% overdrive balancer. Should I torque the supplied bolt to 130lbs with loctite per these instructions?
https://innovatorswest.com/instructi...structions.pdf
I found those on the website but they weren't sent with the balancer. The instructions that came with it said factory specs but you can tell the supplied bolt isn't a tty bolt.
130lbs just seems a little low.
Old Dec 9, 2023 | 03:50 PM
ZMC2001's Avatar
ZMC2001
I have used both the OEM tty bolt and now have swapped to an ARP bolt. For the ARP bolt the directions say 235, so that is what I did, no locktite. If it were me, I would not use red on that bolt as it will probably become impossible to remove after. Also, 130ftlbs seems kind of low, I would probably go a little higher. Just my 2 cents. I'll attach a link to the ARP Dry Sump bolt and its instructions as well incase it would work for your application or you are interested. If I remember correctly, it is a 24mm 12pt socket that I used as well. Hope this is helpful and everything works out.
ARP Dry Sump Bolt
Directions
Old Dec 9, 2023 | 06:16 PM
JosephMingle's Avatar
JosephMingle
I have to admit, I followed the instructions for my A&A kit and installed the bolt included with the Innovators West balancer with red locktite and torqued it to 130 lbs. Getting the stock bolt off was a challenge... until I applied heat and there was lots of thread lock on that bolt.
https://www.aacorvette.com/c7install...tructions.html
Old Dec 10, 2023 | 03:39 PM
deepsouthtech
Thanks. I had the balancer back off on my c6 Z and that is not a fun job to correct so I wanted to make sure.
Old Dec 14, 2023 | 06:23 PM
Chazzmania's Avatar
Chazzmania
When Ist put my A&A kit on like @JosephMingle said I followed the instructions from A&A. I removed the balancer not to long ago for my build and it wasn't that bad getting it off. Just add a floorjack bad to a breakbar it will come right off. I did add a ARP bolt when I reinstalled
Old Dec 15, 2023 | 03:21 PM
ZMC2001's Avatar
ZMC2001
With all the input from other forum members, I would think that you are totally fine following the directions that came with the kit. You shouldn't have an issue. In any case, 130 just seems low to me for a crank bolt, but if it works it works. Good luck on the install.
Old Dec 22, 2023 | 08:09 PM
Lux's Avatar
Lux
Also followed the A&A kit instruction with red loctite. Had no issue getting the factory bolt off though.
To Inovators West Balancer install question
