Help Identifying Chirp During Cold Starts
Old Dec 31, 2023 | 02:45 PM
netster's Avatar
netster
Default Help Identifying Chirp During Cold Starts
2016 Z51, original owner. My car has been making this chirp like sound on cold starts. It goes away within a minute or two. Thoughts on what it could be?
Old Dec 31, 2023 | 04:58 PM
Bill Dearborn's Avatar
Bill Dearborn
I don't hear a chirp. I hear a loud rapid tapping noise. To tell if it is temperature-related pull up your Tour Display on the Instrument Panel where you can see both the coolant and oil temps in digital format to the right of the speedo. Start the engine and note both the coolant and oil temps when the tapping stops. Do this a couple of times to see if the tapping stops at the same temps. My C5Z had the typical LS engine fairly loud piston slap after a cold start but the noise would always reduce and stop when the oil temp approached and then reached 110 degrees. Your tapping is about twice as fast as my piston slap so I figure it might be caused by something in the valve train.
Bill
Old Dec 31, 2023 | 08:10 PM
lbzraptor's Avatar
lbzraptor
On my Duramax the belt chirps until it gets warmed up. Probably due to the pressure the idler pulley puts on the belt. It broke one time and had to use a big pull handle to break the iidler pulley down.
Old Jan 10, 2024 | 08:49 AM
netster's Avatar
netster
Bill, the coolant temp is 80-90 and the oil is only 55 when the sound quiets. Thoughts on next steps, if any?
Thank you
Old Jan 10, 2024 | 10:50 PM
Shokwav's Avatar
Shokwav
Unfortunately I can’t answer your question but I have this same noise in cold start with my mustang. Had it in to the dealer to get it documented and they said it was the belt. I explained to them how this was obviously not the case but they insisted on changing it anyway. To their surprise the sound did not go away. I don’t drive the car much so I’m living with it for now but I’d love to find an answer. I swear it’s coming from a pulley…….
Old Jan 10, 2024 | 11:20 PM
dankhts's Avatar
dankhts
belt chirp is common with a 7 - 8 year old belt... put a new one on and it'll probably cure the noise...
To Help Identifying Chirp During Cold Starts
