Reset remote when changing out its battery?
Old Jan 6, 2024 | 11:54 PM
zipysnotrocket444's Avatar
zipysnotrocket444
Navigator
Default Reset remote when changing out its battery?
Mine is a 2016 Z06. It came with 2 remotes. One needed a new battery and after replacing it, it still won’t work. Do I need to do a reset or what?
Old Jan 7, 2024 | 12:30 AM
Buddhaman's Avatar
Buddhaman
I had an issue when I changed out my battery. Had to press somewhat hard on the chrome strip on the button side. Something "popped" and the remote worked again. I must've taken it apart 3 times checking the battery voltage and that I had it in right.
Old Jan 7, 2024 | 07:51 AM
Tinkertech's Avatar
Tinkertech
Check the battery before you put it in, should be ~3.3 volts.
Make sure that it is inserted into the FOB in the correct orientation. I believe the + side will be up facing you.
Old Jan 7, 2024 | 09:39 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Changing a battery in a working remote does not require a "reset". Put in a good battery (3.3v or so) and have it stitting with the correct polarity in the FOB and it should work immediately as it did previously.
Elmer
Old Jan 7, 2024 | 11:56 AM
H Watkins's Avatar
H Watkins
St. Jude Donor '15-'16, '21,'24
Zipy, you may want to view this video (post #2):
https://www.corvetteforum.com/forums...ferrerid=57001
Old Jan 7, 2024 | 03:34 PM
GOLD72's Avatar
GOLD72
Elmer
Only once have I changed a FOB battery in any car and not have it immediately work. Mercedes FOB and I had the battery polarity reversed!!
To Reset remote when changing out its battery?
