Cabin air filter replacement
Old Jan 8, 2024 | 03:03 PM
kodpkd's Avatar
kodpkd
Default Cabin air filter replacement
My observations that I didn't see on the how to videos. It's easy to get it all scrunched up when installing it. Two things that helped me. Make sure the left and right edges are riding on the small 3/8 inch edges on both sides. It can slip off the edges. Also when the filter slides in, it has to go up as you slide it back, this helps a lot to not scrunch it as it goes in. Use a flash light to look at the inside will help. The one I pulled out was scrunched.
Old Jan 8, 2024 | 04:47 PM
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
I've never had an issue sliding it in....or out.
Old Jan 8, 2024 | 07:10 PM
kodpkd's Avatar
kodpkd
I was a virgin filter installer. The one I removed was all collapsed, it took me 3 tries to slide the new stiff one in, now I'm good at it.
Old Jan 9, 2024 | 01:11 AM
Thanks for your comments. Reminds me I probably need to check my filter.
Old Jan 9, 2024 | 06:09 AM
mdformula350's Avatar
mdformula350
yeah check once a year for me, since I dont drive much, but you never know whats in there so worth a check.
yeah not the smoothest going in for sure, but just take it easy.
To Cabin air filter replacement
