To much oil
Old Jan 10, 2024 | 07:00 PM
kodpkd's Avatar
kodpkd
Default To much oil
2014 LT1. Changed the oil and over filled it a bit. The level is just above the top hash mark on the dip stick. Just leave it, or, OMG it's to full?
Old Jan 10, 2024 | 09:14 PM
Dcasole's Avatar
Dcasole
Dry sump or wet sump
Old Jan 10, 2024 | 09:15 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Dry or wet sump? One is 7 qts the other is 9.8 qts.
wet sump: Stab the stick in and read it.
dry sump: Did you bring it up to 170° oil temp, wait 5 minutes and then check the oil?
Just a hair above the hash, I'd leave it.
Elmer
Old Jan 11, 2024 | 08:47 AM
rtv900's Avatar
rtv900
if cars were that sensitive to oil level there wouldn't be a single car on the road
Old Jan 11, 2024 | 09:18 AM
kodpkd's Avatar
kodpkd
2014 LT1 is a wet sump.
Old Jan 11, 2024 | 09:45 AM
AnotherNorskie's Avatar
AnotherNorskie
Unless it's a Z51.
Old Jan 11, 2024 | 09:50 AM
96GS#007's Avatar
96GS#007
It's fine. Leave it and worry about it in a year when it's time for another oil change.
Old Jan 11, 2024 | 10:10 AM
kodpkd's Avatar
kodpkd
Originally Posted by AnotherNorskie
Unless it's a Z51.
Thank you. It isn't a Z51.
Old Jan 11, 2024 | 10:45 AM
eboggs_jkvl
Moderator emeritus
Unless it's a Z51.
Yup, my 2014 is a Z51 and a dry sump, thus 9.8 qts.
Elmer
Old Jan 11, 2024 | 12:04 PM
Dcasole's Avatar
Dcasole
Wet sump , just a bit over filled is fine , if I am road racing I do overfill by just a small amount ( you don't want to foam the oil )
We asked if it was a Dry sump because how u have to check it is different
Old Jan 11, 2024 | 12:09 PM
kodpkd's Avatar
kodpkd
I understand.
Old Jan 11, 2024 | 09:06 PM
kodpkd's Avatar
kodpkd
I couldn't stand it,,,,, OCD, ****, old man issue. I drained a bit of oil and got the oil on the dip stick to the correct top line. I do know the amount of oil I drained out, doesn't make any difference.
Old Jan 12, 2024 | 08:50 AM
eboggs_jkvl
Moderator emeritus
Elmer
Old Jan 12, 2024 | 09:10 AM
Zjoe6's Avatar
Zjoe6
Yep I'm the same way. Better to just make it right and obsess about something else. Although I might have been able to leave this one alone, hmmm. Or maybe not.
Old Jan 12, 2024 | 10:18 AM
AnotherNorskie
LOL I'd do the same thing. As a DIY guy not under the gun to make a profit by beating flat rate, I have the luxury of spending as much time as I want to make things "right" and I suspect you're in the same boat.
Eexcept I'd extract it out of the dip stick tube.
Old Jan 12, 2024 | 10:37 AM
kodpkd's Avatar
kodpkd
I tried to use a small 1/4" OD tube, it doesn't fit down the dipstick tube. I looked at the hardware store for a smaller OD tube, no joy. There is a restriction at the end of the tube to allow the diameter of the end of the dipstick to just fit.
Old Jan 13, 2024 | 08:47 AM
AnotherNorskie
I tried to change my oil with an excavator but I couldn't get down to the bottom of the oil pan - I didn't realize that the restriction was that high up. That's annoying. Oh well, need to get under the vehicle to change the oil filter anyways, and at least there aren't a bazillion body panels to remove to get at it.
Top-side oil filters and sucking oil out through the dipstick has got to be one of the best car innovations ever.
To To much oil
Old Jan 16, 2024 | 01:08 AM
Avanti's Avatar
Avanti
You did just as I'd have suggested had I been by sooner. Now, go for a drive... if your weather is cooperating.
Old Jan 18, 2024 | 04:28 AM
Technically nothing wrong with being precise, but if it was just a small amount, you probably would have been just fine.
Old Jan 18, 2024 | 11:05 AM
kodpkd's Avatar
kodpkd
I never said how I drained it. I made sure the oil was cold, unscrewed the drain plug carefully and kept it in the hole and pulled it out just enough to have it flow a bit. The oil being cold helped a lot. It didn't burn my fingers and flowed very slow.
