Girodisc Conversion
Old Feb 10, 2024 | 05:12 PM
atejadaz06's Avatar
atejadaz06
Default Girodisc Conversion
I have a 2017 C7Z with the carbon ceramic brakes and I just got the girodisc conversion rotors for front and rear.
Does anyone know the Hawk brakes part number for them?
Rear: HB453G.585 or HB910G.590
Front: HB649B.605
This is what I’ve seen online but I just want to make sure.
Old Feb 11, 2024 | 12:57 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
where did you get your rotors from? i am also going to steel rotors to replace the ccb's on my 17' gs/z07.
Old Feb 12, 2024 | 05:55 PM
atejadaz06's Avatar
atejadaz06
[size=13px]A vendor on the forum KNSbrakes. Ken has been very helpful with everything, would recommend him 100%.[/size]
https://www.corvetteforum.com/forums/members/257726-knsbrakes.html
Old Feb 18, 2024 | 12:45 PM
BrunoTheMellow's Avatar
BrunoTheMellow
Here’s a simpler way to find pads:
front pad size is the same as any other z06 or grand sport front brakes
rear pad size is the same as any base c7 or c7 z51 FRONT pads
also note that the rear pads virtually don’t wear. You’ll run the same pads forever. And if you’re tracking, make sure to use rear pads a little less aggressive than front.
To Girodisc Conversion
