Yeah, I have the whole kit. It had a tighter fit with the TSP cam. I have a btr cam now. I am probably going to order the Katech timing gear. It looks like a better design.
pretty sure they both have the same cam gear. if you do swap it out and want to sell the lme tensioner let me know
If it's possible I am going to order just the gear from katech. They modified the gear differently from lme. The lme gear has a bigger hole and uses a bushing on the cam dowel. The katech looks like a smaller hole and doesn't need the bushing on the dowel.
interesting research. mine has the bushing as well. let me know what gear you order if you dont mind . im still collecting parts for the swap but if mine has play ill need a different sprocket.
my research for those asking about the sprocket being a ls gear is that its different from the timing mark perspective
