2016 misfire problems and other
Old Mar 4, 2024 | 01:28 AM
MeVette's Avatar
MeVette
Default 2016 misfire problems and other
My vette had to limp home after the first nice day in awhile I live in the Pittsburgh area. The corvette shakes very badly from according to my obd dx tool is a general misfire, it also as a stabiltrack error and a service rear warning on the info screen if car. I live near bowser chevy. What’s the best place to have it flat bedded and do I have to call to make sure they can work on it this is the first time I had a mechanical problem with a vehicle which wasn’t under warranty.
thanks for your time. Any help would be appreciated.
Old Mar 4, 2024 | 02:31 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
If you’re near Bethel Park take your car to Danner Automotive…”Danner” who is Paul Danner’s brother owns the shop…Paul (Scanner Danner) is one of the best diagnostic techs in the country…sent a few Corvette owners his way…the 2 warnings are a result of having a P0300 misfire…when you get the misfire fixed they will go away.
Old Mar 8, 2024 | 11:48 PM
RonC7's Avatar
RonC7
Service stabilitrak and service rear axle are often due to communications issues caused by a weak battery. Have your battery checked or just replace it if 5 or more years old before looking for other problems.
Also check that your spark plug and coil wires have not come loose as this can cause a misfire.
Ron
Old Mar 9, 2024 | 07:33 AM
Dcasole's Avatar
Dcasole
Ron
Stabilitrak and service rear axle warnings are a result of another problem as the ECM starts to shut down modules when it detects a major fault , while a low battery will cause it, clearly in this case it is caused by the missfires ..
Dave
To 2016 misfire problems and other
