stored car fluid changes
Old Mar 12, 2024 | 11:38 AM
DCortez's Avatar
DCortez
Default stored car fluid changes
How often would you change brake, transmission, and radiator fluid on a stored car?
Old Mar 12, 2024 | 12:28 PM
spoolin98's Avatar
spoolin98
You need to be more specific. Do you mean stored for the winter? If so, I wouldn't change any of those fluids.
Old Mar 12, 2024 | 12:42 PM
DCortez's Avatar
DCortez
Stored for 4-5 years at a time without driving.
Old Mar 12, 2024 | 12:57 PM
spoolin98's Avatar
spoolin98
If it were my car, I would change the oil before storing and again before starting it 4-5 years later.
I would pull the battery and put it on a tender in a controlled temp environment.
I would not do anything to the brakes before storage, I would bleed the brakes before driving, I do this every season just to get fresh fluid in the calipers/system.
Coolant System I would not do anything before storing, make sure it's topped off before driving.
Transmission I would change the fluid on the mileage intervals the manufacturer calls for.
This is just my opinion; I am sure others will have their own opinions.
Old Mar 12, 2024 | 12:58 PM
spoolin98's Avatar
spoolin98
Amsoil used to make an oil for long term storage, but I can't seem to find it, they may have discontinued it.
Old Mar 12, 2024 | 04:04 PM
CPB's Avatar
CPB
I'd change them before going into storage, then monitor for acidity.
Old Mar 15, 2024 | 05:54 PM
Bill Dearborn's Avatar
Bill Dearborn
If going into a long-term storage such as 5 years I would change the brake fluid, coolant and engine oil. The OM states the brake fluid and the coolant should be changed every 5 years no matter how few miles. The engine oil should be changed every year no matter how few miles. Assuming the car has some miles and some time on it since those items were serviced the last time all of them should be serviced when putting the car into storage and when taking it out of storage.
Bill
To stored car fluid changes
