Stability control module
Old Mar 14, 2024 | 11:37 AM
KirillG88's Avatar
KirillG88
Default Stability control module
Hi, anyone can tell me if SCM from Camaro ZL1 for example will fit Corvette C7 GS ? If the part number is the same? P/N: 84180580
I found in eBay SCM 84180580 , applicable both for Vette and Camaro , but the one for Camaro is half price cheaper. So I'm curious if it will me
https://www.ebay.com/itm/126309479937
https://www.ebay.com/itm/395235530839
Old Mar 15, 2024 | 06:33 PM
Bill Dearborn's Avatar
Bill Dearborn
Not sure what you are looking for. Stability Control is a function of the ABS module. GM doesn't show a Stability Control Module in their parts list. If you mean suspension control module then there are two different suspension control modules for the C7 series. One covers 2014-2017 and the other covers 2017-2019. Here is what I pulled off a GM Discount Parts Vendor website. I can't find the 84180580 part number on the parts website.
Bill
Old Mar 16, 2024 | 12:54 AM
KirillG88's Avatar
KirillG88
Bill
Hi Bill, you are right the GM site for some reason doesn't show this module on their site and i don't know the reason for that. But I do have this module in the trunk floor beside with fuseboxe and Bose amp. As far as I understand it from the tech he said it's a stability control module and indeed related to abs function. I have communication DTC all the time and he believes that this error coming from this module because I had water in this place and this module was flooded.
The suspension control module is other thing, I have this module as well but it's located behind the driver-side fender, and no issues with it
My car btw is C7 GS 12/2016
Old Mar 19, 2024 | 06:02 PM
Bill Dearborn
Originally Posted by KirillG88
Hi Bill, you are right the GM site for some reason doesnt shoe this module on their site amd i don't know the reason for that. But I do have this module in the trunk floor beside with fuseboxe and bose amp. as far as I understand it from the tech he said it's stability control module and indeed related to abs function. I have communication dtc all the time and ge believe that this error coming from this module, because I had water in this place and this module was flooded.
Suspension control module is other thing , I have this module as well but it's located behind the driver side fender and no issues with it
What is the communications DTC you are seeing and are there any other DTCs? Also, do you have any Service Messages appearing on the DIC or warning lights? What isn't working? Does traction control work? Does stability control work? These are things you can test for in an empty parking lot with a heavy right foot and sharp steering.
Bill
Old Mar 19, 2024 | 07:29 PM
KirillG88's Avatar
KirillG88
Bill
1. I don't exactly remember, I'll read the errors and let you know the exact codes, but they were related to the ABS sensor rear right wheel and something with the wheel speed sensor invalid signal
2. "are there any other DTCs?"
- Yes , I have also 2 of these codes P26C8 and P12EA
3. "
do you have any Service Messages appearing on the DIC or warning lights?"
- Yes I do , while driving, suddenly appears check engine light along with "abs" light, service stabilitrek and service rear axle
To Stability control module
