redline stutter
Old Mar 27, 2024 | 10:46 PM
p0p_sm0k3's Avatar
p0p_sm0k3
Cruising
Default redline stutter
I have a 16 stage 3 cam m7 666 to the wheels. I was getting on it and when i would get close to redline it would stutter then go away and again close to redline same thing. Next day I ripped it at the light and then SERVICE rear axle light came on. Started back up and came back on. Im thinking i need to change the spark plugs. Any ideas? and if spark plugs should i do coil packs as well? if so what spark plugs should i go with and coils?
Old Mar 28, 2024 | 11:38 AM
96GS#007's Avatar
96GS#007
You need to log what's going on, otherwise you'll just be guessing and shooting the parts cannon at it.
Old Mar 29, 2024 | 10:35 PM
gordoni's Avatar
gordoni
Are you hitting the rev limiter?
Old Mar 30, 2024 | 07:00 AM
Dcasole's Avatar
Dcasole
^^^^^^^^^^^THIS^^^^^^^^^^^^^
It could be a million things , plugs maybe , wires , maybe , fuel preasure , maybe , valve float , maybe , knock retard , maybe, coils highly unlikely....
Don't shoot the parts cannon at it .... log the car and see what's going on
Dave
Old Mar 31, 2024 | 05:31 PM
Citation's Avatar
Citation
Check the small gauge ground wire at the battery. It needs a really clean connection. Many symptoms from that wire. Service rear axle is top of the list.
Old Apr 9, 2024 | 03:24 PM
LT1GMC's Avatar
LT1GMC
Need to log, keep close eye on fuel pressure. Good chance its running low at top rpm, have seen that a few times, especially if no upgrades with mods you have done.
To redline stutter
