C7 Header Install Cost
Old Apr 1, 2024 | 06:18 PM
Ken_4fun's Avatar
Ken_4fun
Default C7 Header Install Cost
I have a young guy I use for miscellaneous automotive work.
I was thinking about having him installing headers and x-pipe. What would be a fair price for labor if I supplied all parts?
Ken
Old Apr 2, 2024 | 11:25 AM
96GS#007's Avatar
96GS#007
I recall a header install being in the neighborhood of 8 hours. Multiple that times whatever hourly rate you're paying...$50/hr for a side hustle?...so $400.
Don't forget that with no aft o2 sensors you'll need it tuned or you'll get a check engine light. In addition, when getting it tuned you may as well optimize it for power. I'll assume the young lad doesn't have a dyno and HP Tuners so you'll want to figure out where to go for that.
One other thing....depending on header brand, they may not clear the tunnel plate. You'll either need to add spacers or cut the plate.
Old Apr 2, 2024 | 02:19 PM
FRED HAMBLE's Avatar
FRED HAMBLE
What about having the A8 tran reprogramed ??
Old Apr 2, 2024 | 04:51 PM
96GS#007's Avatar
96GS#007
Are you asking a question or making a suggestion to the OP?
Old Apr 3, 2024 | 05:26 AM
mdformula350's Avatar
mdformula350
yeah would guess 400 to 500 ish as well. definitely takes some time.
you could also call around to some performance places to see what they charge, most likely going to be much higher but just for reference and research, could also gauge on what they say how long it takes as well..
Old Apr 3, 2024 | 02:01 PM
FRED HAMBLE
Question as an installer mentioned that on some C7 A8 u need to have the tran reprogramed.
Old Apr 3, 2024 | 04:48 PM
96GS#007's Avatar
96GS#007
Not for headers. Can do it for driveability preference, but it's not required.
Old Apr 4, 2024 | 07:51 PM
rackemup's Avatar
rackemup
$400 for install is a deal. I've done it 3 times, it is a ball buster without a lift.
Old Apr 4, 2024 | 09:02 PM
96GS#007's Avatar
96GS#007
$400 is not what a shop would charge....figure at least 4x that amount....but if he "has a young guy he uses", it sounds like a side hustle which means the guy has no taxes or overhead to worry about.
Old Apr 5, 2024 | 05:37 PM
Thomasmoto's Avatar
Thomasmoto
Default header install
Ken
Just my .02, but I wouldn't have an inexperienced person to do that job. Lots of things that can go wrong.
Old Apr 5, 2024 | 09:56 PM
eseibel67's Avatar
eseibel67
Agreed. If young guy knows what he's doing and takes his time to ensure he doesn't break anything and can show me a previous job similar to this that he's done before for a happy owner then np. Unlikely for $400, this job isn't painting a fence. Do it yourself or use a pro.
To C7 Header Install Cost
