C7 z06 p0033 p0034
Old Apr 10, 2024 | 11:36 PM
juann22's Avatar
juann22
Navigator
Default C7 z06 p0033 p0034
Hey guys I was driving down the highway getting on the car a little bit when I got these codes, when I got off the highway the car seemed very sluggish and slow and I got a “power reduced” message on my screen if you guys can help to figure out what the problem is I would greatly appreciate it.
Old Apr 11, 2024 | 08:35 AM
Tinkertech's Avatar
Tinkertech
Looks like the supercharger bypass valve is having problems.
Check all of its wiring before replacing bypass unit.
I would not worry about the Evap DTC right now.
Are you using a high grade scanner or a simple code reader, makes a difference.
Old Apr 12, 2024 | 02:13 AM
juann22's Avatar
juann22
Navigator
Default scanner
Hey thank you but I see no problems in the wiring I am using a simple code scanner where could I find one that your talking about ?
Old Apr 12, 2024 | 07:12 AM
Tinkertech's Avatar
Tinkertech
There are a lot of manufactures that make good scanners.
Mine is made by Autel, MP808TS.
Cost ~$700.
It is a mid grade level scanner, good but not the best.
Just depends on how much you want to spend.
They can get very expensive.
Old Apr 12, 2024 | 11:12 PM
juann22's Avatar
juann22
Navigator
Default P0033 p0034
Cost ~$700.
Hey I just ordered the solenoid and the bypass valve from a gm website do you think I should install it or take it to the shop for it to be installed I would appreciate your opinion thank you
Old Apr 13, 2024 | 10:44 AM
Tinkertech's Avatar
Tinkertech
It all depends on your abilities And whether or not you have the correct tools
Old Apr 14, 2024 | 08:06 PM
juann22's Avatar
juann22
Navigator
Default P0033 p0034
Hi guys tinkerer or anyone else I replaced the supercharger actuator it helped a little but the cars still runs a
rough I just ordered the solenoid any other ideas that can help thank you guys
Old Apr 16, 2024 | 09:28 PM
juann22's Avatar
juann22
Navigator
Default P0033 p0034
Hey guys I just replaced the actuator and the solenoid and it’s still running bad and has the same codes any other ideas
Old Apr 17, 2024 | 07:54 AM
Tinkertech's Avatar
Tinkertech
Sounds like your at the point of just throwing parts at it. Sometimes it works, sometimes not.
Maybe something in the Evap system since it was showing up on your DTC reader.
Need to put a scanner on it to be sure and go from there.
You did check all the plugs, wires and coils first, right?
Old Apr 17, 2024 | 03:49 PM
juann22's Avatar
juann22
Navigator
Do you think this is a missfire
Old Apr 17, 2024 | 05:24 PM
Tinkertech's Avatar
Tinkertech
Can’t tell without a scan tool.
If you just wanna throw parts at it, I start at the spark plugs, then the spark plug wires, and then the coils.
But you really need to hook up a scan tool to see what’s going on or you’re just guessing
Old Apr 18, 2024 | 04:38 AM
juann22's Avatar
juann22
Navigator
Hey sorry I may be just throwing things at it at this point but it might be the throttle body is my next guess I did the spark plugs a while ago and had no problem with them right after but your saying coils and wires next instead ?
Old Apr 18, 2024 | 07:27 AM
Tinkertech's Avatar
Tinkertech
Dang, it sounds like the engine is badly hanging on about ready to stall at any moment.
At this point you really need a good scan tool to move forward.
I could think of a dozen different things to cause this but throwing parts at it is not one of them.
Scan tool time. ( the problem will probably jump out at you ).
Good luck.
Old Apr 18, 2024 | 02:30 PM
juann22's Avatar
juann22
Navigator
Old Apr 19, 2024 | 07:42 AM
Tinkertech's Avatar
Tinkertech
Is the engine / car factory stock?
O2 issues should not cause it to run this rough. When the heaters fail the ECM goes into a default mode and pops a cel. Had this happen on my 06 GT Mustang, heater failure DTC. Turned out to be a defective PCM. But car ran normally. Only the heater circuit inside the PCM was intermittent which I was able to troubleshoot and repair.
On your car I'd start looking at a misfire, dead cylender or the valve springs. Pop the valve cover and inspect the valve springs. On my Autel scanner I can pick out a bad or missing cylinder easily. ( also had this happen on the same 06 Mustang, found #2 cylinder intermittently dropping out, inspected spark plug ( bad ) then replaced it, problem fixed ). But the car never ran rough like yours.
You could also have a large vacuum leak from the evaporation system since the code reader gave you a DTC for this system. ( hose split or came off ). I've found that an ultra sonic leak detector comes in handy finding vacuum leaks.
You need to dig deeper or maybe find a diagnostic shop for help. All depends on your ability and diagnostic tools,
Good luck and don't forget to tell us what you end up finding.
Old Nov 25, 2025 | 04:16 AM
c7totan's Avatar
c7totan
1st Gear
Default Did you solve this I’m currently having the same exact issue???
Did you solve this
To C7 z06 p0033 p0034
