Coolant replacement
Old Apr 16, 2024 | 04:08 PM
meikel24's Avatar
meikel24
Default Coolant replacement
Would anyone have OEM instructions for changing the coolant on the C7 Z51 Stingray?
Thank you
Michael
Old Apr 17, 2024 | 07:57 AM
Tinkertech's Avatar
Tinkertech
A lot of write ups on this site if you search.
Not hard, just time consuming to do it right.
Old Apr 17, 2024 | 09:18 AM
meikel24's Avatar
meikel24
Thanks for the tip, I found a lot, unfortunately with very different methods, which is why I asked for OEM instructions, it's about the correct bleeding without a bleeding device.
Old Apr 18, 2024 | 07:44 AM
Tinkertech's Avatar
Tinkertech
I always use a vacuum system to purge all the air out of the system.
Lost an engine once when I had a trapped air pocket in the head. Blew the head gasket, warped the head.
Yes, the engine was suppose to be self purging.
Oh my! Look at all the pretty little bubbles in the over flow tank!!!
Old Apr 18, 2024 | 09:58 AM
meikel24's Avatar
meikel24
Danke für die Antwort, das Vacuumentlüftungsgerät ist preiswert, leider braucht es dazu einen großen Kompressor, unser Kompressor reicht dazu nicht aus. Es ist aber die sicherste Methode, das Kühlsystem richtig zu befüllen und gleichzeitig zu entlüften. Ich werde wohl eine Mietwerkstatt dazu aufsuchen und es mit Vacuum machen.
Wenn ich den warmen Wagen abstelle und die Heizung vorher auf max. stelle, bleiben die Ventile zu befüllen dann offen?
Old Apr 18, 2024 | 12:42 PM
westsdad's Avatar
westsdad
German to English translation:
Thanks for the reply, the vacuum venting device is inexpensive, unfortunately it needs a large compressor for this, our compressor is not enough for this. However, it is the safest way to properly fill the cooling system and bleed it at the same time. I'll probably go to a rental workshop and do it with Vacuum. If I park the warm car and set the heating to max. beforehand, will the valves to be filled remain open?
A subscription to AllData DIY may be for you if you want OEM processes: https://www.alldata.com/diy-us/en
Old Apr 18, 2024 | 04:25 PM
meikel24's Avatar
meikel24
Thank you. Unfortunately the offer is not available in Germany. I would have liked to read whether GM describes refilling without vacuum. I would also like to be careful because I know the problem with air bubbles in the cooling system from our Opel GT (same as Saturn Sky) forum with the possible consequential damage.
Greetings Michael
Old Apr 18, 2024 | 06:06 PM
westsdad's Avatar
westsdad
Greetings Michael
Hallo Meikel,
I didn't think about the non-availability of AllData in Germany. A VPN through a USA server wouldn't work either as your credit card would tie you to Germany.
I've searched a lot and have not found the factory process for engine coolant replacement. It would be prudent to bleed the system after replacing to prevent any potential damage from entrapped air.
Here's the adapter that I use for engine coolant bleeding. The Mopar one was created by the 'Cooler Bleeder owner when I asked about bleeding the Super Charger cooling system in my Hell Cat and Hell Cat Redeye. The SC cooling system and the engine cooling system use the same radiator cap.
https://www.coolerbleeder.com/radiator-bleeding
I use the 'Cooler Bleeder for bleeding the air from my Z06 and HC super charger and engine cooling systems.
I use the following vacuum pump for it and when bleeding the engine coolant systems.
https://www.amazon.com/Robinair-15500-VacuMaster-Economy-Vacuum/dp/B000O1C47M/ref=sr_1_5?crid=341BGG4F0JN59&dib=eyJ2IjoiMSJ9.o9FlayA1Ieb7h66RVzPzp-DZR_weSGUxyrWUpzX8AW1ckyhN-tnrcknyS8jrxOvwAMujrYgQairPiMmkNYHPVVGFV9MgMAyDJTPkylAFS9vCFbpvuhpLeFDVnsy0q7Z7NIdthE1OHDZpEGkbZODu8xBGB8eo0Egi3tc7hqMjfMUi01_Xsl_Llnr9Udjxq3IQHWrxEecFtiLMTsaCiURI-ALIz4-bL3QeT8Vb47_Itq4fU9YODx3c_BVUnXZVHFHn4jkQFhfWSLG2jQZeoEaSj1R2oQWLOuYEbrzjK8rInrI.CzTrKwNiUvORVSeBA1skzlI8l8M9EHaVsDUh-R0jfG8&dib_tag=se&keywords=robinair+vacuum+pump&qid=1713474699&sprefix=robinair+vacu%2Caps%2C117&sr=8-5 https://www.amazon.com/Robinair-15500-VacuMaster-Economy-Vacuum/dp/B000O1C47M/ref=sr_1_5?crid=341BGG4F0JN59&dib=eyJ2IjoiMSJ9.o9FlayA1Ieb7h66RVzPzp-DZR_weSGUxyrWUpzX8AW1ckyhN-tnrcknyS8jrxOvwAMujrYgQairPiMmkNYHPVVGFV9MgMAyDJTPkylAFS9vCFbpvuhpLeFDVnsy0q7Z7NIdthE1OHDZpEGkbZODu8xBGB8eo0Egi3tc7hqMjfMUi01_Xsl_Llnr9Udjxq3IQHWrxEecFtiLMTsaCiURI-ALIz4-bL3QeT8Vb47_Itq4fU9YODx3c_BVUnXZVHFHn4jkQFhfWSLG2jQZeoEaSj1R2oQWLOuYEbrzjK8rInrI.CzTrKwNiUvORVSeBA1skzlI8l8M9EHaVsDUh-R0jfG8&dib_tag=se&keywords=robinair+vacuum+pump&qid=1713474699&sprefix=robinair+vacu%2Caps%2C117&sr=8-5
This tool could be also be used with a vacuum pump.
https://www.amazon.com/WIN-MAX-Engine-Cooling-System-Universal/dp/B0787JQSFH/ref=sr_1_10?crid=2Z3B2UO00003M&dib=eyJ2IjoiMSJ9.ee7KKNOBMxd7aHxTKL90MJ6NF_ls6er__n_ymuzZN_bOfp8l9m46CxX2gkLyhq3mtbAONzXmW6_qKN_Lmm-7ulEJ7vTfYYWJE3_Xa5k5zxhBo096Z7aVMj0LD0yMK19jp9O3m85y8-KG2vG0UFJmFARHZrgucYJQQPENkSW5-n3rFaJG4qMVW5-geXWQnU1CbuwPrCmQUPasCI3YQMQXg9jFyy9L8Vh3sumGEEDy0dxdkNMEitlPegjG_iKGT_afYsYlPVrN1tATDXW2To2P3NyA7Sx25ZwFi30p6NpRRFo.oUaHwzaxpz-vwNGsntFa5836th2wzwJVYBYcpJRvdDo&dib_tag=se&keywords=cooling+system+bleeder+kit&qid=1713474872&sprefix=cooling+syste%2Caps%2C116&sr=8-10 https://www.amazon.com/WIN-MAX-Engine-Cooling-System-Universal/dp/B0787JQSFH/ref=sr_1_10?crid=2Z3B2UO00003M&dib=eyJ2IjoiMSJ9.ee7KKNOBMxd7aHxTKL90MJ6NF_ls6er__n_ymuzZN_bOfp8l9m46CxX2gkLyhq3mtbAONzXmW6_qKN_Lmm-7ulEJ7vTfYYWJE3_Xa5k5zxhBo096Z7aVMj0LD0yMK19jp9O3m85y8-KG2vG0UFJmFARHZrgucYJQQPENkSW5-n3rFaJG4qMVW5-geXWQnU1CbuwPrCmQUPasCI3YQMQXg9jFyy9L8Vh3sumGEEDy0dxdkNMEitlPegjG_iKGT_afYsYlPVrN1tATDXW2To2P3NyA7Sx25ZwFi30p6NpRRFo.oUaHwzaxpz-vwNGsntFa5836th2wzwJVYBYcpJRvdDo&dib_tag=se&keywords=cooling+system+bleeder+kit&qid=1713474872&sprefix=cooling+syste%2Caps%2C116&sr=8-10
Old Apr 18, 2024 | 07:36 PM
96GS#007's Avatar
96GS#007
There's nothing really complex or unusual about the LT1. Pretty much the same as any other engine. The GM docs are attached.
File Type: pdf
Old Apr 19, 2024 | 10:04 AM
meikel24's Avatar
meikel24
Originally Posted by westsdad
Hallo Meikel,
https://www.amazon.com/Robinair-1550...s%2C117&sr=8-5
https://www.amazon.com/WIN-MAX-Engin...%2C116&sr=8-10
Thank you very much, the idea with the vacuum pump is great. I got the oem manual for the filling and I think about.
Greetings and a nice weekend from Germany
Michael
Old Apr 19, 2024 | 10:07 AM
meikel24's Avatar
meikel24
Thank you very much for the manual, great forum !!!
greetings and a nice weekend from Germany
Michael
Old Apr 19, 2024 | 10:13 AM
CPB's Avatar
CPB
Thank you
Michael
PDF attached two different methods.
File Type: pdf
File Type: pdf
To Coolant replacement
