Flooded C7 Z06
Old May 7, 2024 | 07:35 PM
MillerVettte's Avatar
MillerVettte
2nd Gear
Default Flooded C7 Z06
Hey guys,i bought a flooded 2016 C7 Z06 ,ive managed to get the motor started but cant seem to get the Hvac controls and radio display to work . I installed and programmed a new BCM . and also bought a new radio unit located at passengers feet and last changed the Hvac controls . For your information the water rose to just under the display . Thanks
Old May 7, 2024 | 08:02 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
A flood car ??…good luck with that !!…hope your good at diagnosing electrical issues because down the road you’ll be spending most of your time doing that…was it a Florida car ??
Old May 7, 2024 | 08:11 PM
MillerVettte
2nd Gear
No , fresh water easter Canada.
Old May 14, 2024 | 01:29 PM
TraceZ's Avatar
TraceZ
The only way to properly repair that is to obtain a parts car that is the same year and trim level, then transfer all wiring that got wet into your flood car.
If it got wet, it needs to be replaced, 100%.
Old May 14, 2024 | 03:15 PM
cdq85's Avatar
cdq85
Water up to the display??? You're a brave, brave man.
Old May 14, 2024 | 04:50 PM
Midnight_rider's Avatar
Midnight_rider
First thing I'd do is to replace all of the wiring harnesses.
Old May 14, 2024 | 11:24 PM
Good luck - I have a feeling you are going to have your work cut out for you.
Old May 15, 2024 | 08:15 AM
hiltsy855's Avatar
hiltsy855
I considered buying a flooded car at one time. If you bought it right ($) it will be worth the effort. A fresh-water flooder is certainly better than saltwater. If you've got it down to HVAC & display you've done well. As was mentioned, replacing the wiring harness is probably in order, at least the interior harness that connects to the 2 systems you're having issues with.
To Flooded C7 Z06
