Shifter knob rattles
Old May 9, 2024 | 01:15 PM
F100shooter's Avatar
F100shooter
6th Gear
Default Shifter **** rattles
My C7 manual transmission shifter **** rattles as I drive. It’s just the little plate with the shift pattern on it that rattles or vibrates and makes noise as I drive. Anyone have a fix? Not sure how to remove the plate without damaging it.
Old May 9, 2024 | 02:18 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Our team would like the opportunity to learn more about the rattling concern on your C7 and investigate ways we can potentially assist. When you get the chance, please send an email to socialmedia@gm.com. Be sure to include your Username and Forum name in the subject line, then provide additional details about your experience in the body of the email. We look forward to your contact.
Old May 9, 2024 | 02:41 PM
fuzzy03cls's Avatar
fuzzy03cls
Had this happen to an older Explorer 5 speed. I cut up a sock & stuffed it inside the **** & the pressure once put back on made it stop.
Old May 9, 2024 | 02:53 PM
NortonCO's Avatar
NortonCO
Same here, though I'd describe it as more of a vibration that a rattle.
Not sure what additional details you need? The vibration in mine goes away by resting my hand on the shift ****, but it is an annoying issue.
Old May 9, 2024 | 08:00 PM
Flattman's Avatar
Flattman
While I haven't had the problem, I thought I remembered reading some threads on this. Below are some quick search results and while some of the posts are regarding aftermarket *****, there are some good ides sprinkled within them that might help you.
https://www.corvetteforum.com/forums...***-ratle.html
https://www.corvetteforum.com/forums...ubleshoot.html
https://www.corvetteforum.com/forums...hift-****.html
To Shifter knob rattles
