Coolant temp
Old May 21, 2024 | 11:33 AM
flynhi's Avatar
flynhi
Default Coolant temp
Recently the ambient temp in Austin hit 93, Th temp gauge in my 17 ZO6 with AC on hit 242. Is this normal or is my radiator fan operating at too low an RPM?
Your replies appreciated.
Old May 21, 2024 | 11:37 AM
Red86Cfour's Avatar
Red86Cfour
Something isn't right I've run my stingray in 100+ degree temps and it doesn't run any different than when in 60 degree temps. I'd be checking thermostats as they do fail and yours is at that time when they could start failing. I'd start there.
Old May 21, 2024 | 11:39 AM
flynhi's Avatar
flynhi
Will a failed thermostat show up on OBD?
Old May 21, 2024 | 04:41 PM
ZMC2001's Avatar
ZMC2001
Yeah, that is way too hot. I would check the thermostat first and then look to the water pump if the thermostat is not the issue. You can put the thermostat in a pot of boiling water and see if it will open to test as well. Wierdly, in my C6, it was overheating like crazy, I thought it was the thermostat, bu tit turned out to be that the radiator was literally splitting apart. No clue how this happened, but was quite a pain. I would definitely get that addressed pronto though, 242 temps are much too high.
Old May 21, 2024 | 08:38 PM
RonC7's Avatar
RonC7
There was a problem on some 2014s with the fan controller (can really happen to any year car). It is built in to the fan assembly, so the entire fan assembly needs to be replaced. Many replaced with Z06 units. (I had no problem with my 2014).
Here's one of many threads on the issue:
https://www.corvetteforum.com/forums...-to-260-a.html
Ron
Old May 22, 2024 | 08:43 AM
Tinkertech's Avatar
Tinkertech
Is it really overheating or just the analog gauge says so?
Put your DIC in performance mode and read the temp.
If you have a scanner you can read the temp also. Most people don't have one at home.
Maybe just a bad temp sensor, but also a stuck closed thermostat.
If it is really overheating the fan should be running full speed, you will be able to hear it roar. Also the AC should shut down, car goes into limp mode and warnings appear on the DIC.
If its overheating the radiator hoses will be very hard, can't squeeze them, overflow tank should be overflowing if it really gets hot.
Take a reading with a hand held IR temp gauge, point and shoot, ( cheap and easy to acquire) on the radiator and its hoses. Very rough reading, but a simple start.
What I'm trying to say is there are a lot of simple tests you can do to diagnose this issue.
But if its appears to be overheating after doing some simple tests, I'd change the temp sensor and the thermostat. Both cheap and simple to do at home.
But don't let it keep overheating, if it really is, or you will have bigger problems.
Old May 22, 2024 | 06:19 PM
96GS#007's Avatar
96GS#007
Make sure there not a bunch of debris in front of the AC condenser thereby blocking the radiator. Just look through the grill. I've seen more than one time that someone sucks up a piece of newspaper or a plastic bag and it blocks the flow to a third of the cooling stack.
Old May 23, 2024 | 09:14 AM
Red86Cfour's Avatar
Red86Cfour
Originally Posted by flynhi
I'm not sure. Sometimes the symptoms aren't obvious. Since you have a zo6 the fan controller shouldn't be the problem like the problems with the stingray fan controller of the first few years. I would verify that it really is overheating and not by the analog gauge, but by the digital readout on the performace screen like was mentioned previously.
Old May 23, 2024 | 09:20 AM
1Hotrodz's Avatar
1Hotrodz
Check this first before anything else, then check the coolant level. And Like others have said, yes your cooling fan should be roaring at those temps.
Old May 23, 2024 | 09:39 AM
96GS#007's Avatar
96GS#007
Nope
To Coolant temp
