Soler Performance Ported Throttle Bodies and Throttle Controllers
Website: Soler Performance | General Motors
Email: tiffany@solerengineering.com
Text/call: (850) 512-9262 Mon-Fri 8am-5pm
June Discount code: SALE5P
Premium Modified, Ported, and calibrated Throttle Bodies
DLX Bluetooth Throttle ControllersFEATURES:
• Optimized Active Contours with sonic flow nozzles
• Porting Taper and Upstream Bore with Velocity Stack
• Greater Discharge Coefficient of Plate/Blade interface
• 16 Ra Microinch, Diamond Polished Surface Finish
• Shaftless high-pressure side of the blade for Larger WOT Flow Area
• Self-Cleaning Throat/Flow Gap
• Dome and Thread-locked Screws
• Dimpled shaft trailing edge
BENEFITS:
• Lower weight to power ratio at part throttle, for a more nimble/spirited driving experience
• Linearization and smoothing of the curve for a more predictable response and crisper shifts
• Immediate response right off idling while keeping idling function undisturbed (No Hesitation/Stumble)
• Does not require tuning. Warranty safe.
• More air/power at every single throttle position after idle. Crucial for starting or expanding power gain modifications
• Easy Installation
SE8223-040, 87 MM (91 MM EFF.) Corvette 7/8, Stingray/Z51/GS (2014-Present).
SE8223-080, 87 MM (91 MM EFF.) LT4 Corvette 7, Z06, 2015-2019.
SE9871-100, 95+ MM / 100MM EFF. LT5/ZR1 Corvette C7 and C8 (LT1/LT2/LT4/LT5 Engines), 2014-Present.
SE1000-103 (103 MM TB) Corvette 7, and 8 (2014+)
FEATURES:
-Dual control, directly on the display or remotely from your smart device.
-Ten Modes, with a total of 64 possible settings (see chart).
-Sturdy aluminum construction, buttons, and heavy-duty harness.
-Self-adjusting OLED display intensity for optimum visibility.
-Real-time throttle position gauge.
-Fail-safe vehicle-specific design.
-Does not require the display to operate, for those who prefer a fully concealed device.
BENEFITS:
Controls pedal sensitivity, allowing the driver to adjust an otherwise widely considered non-linear (slow/spongy) pedal response/map.
Increases the sensation of acceleration/power, very important for driving pleasure in finely tuned sports cars.
Complements performance Throttle Bodies in achieving total throttle control as a system.
Plug-and-play modification.
Warranty safe modification.
Easy installation (15 min, no tools or special skills required).
SE0525-TC DLX BLUETOOTH® THROTTLE CONTROLLER Corvette 7/8th Gen. (2014-Present) - C7 & C8.
Text/call: (251) 468-9786 Mon-Fri 8am-5pm
