Transmission Fluid
Old Jun 10, 2024 | 02:02 PM
2019yellow's Avatar
2019yellow
7th Gear
Default Transmission Fluid
I have a 2019 GS 3LT with 4900 miles. I have recently noticed some mid speed (60-70 mph) shuddering experience occuring. I have new Michelin tires on the vehicle which I recently inspected to be OK. Has anybody experienced this problem. I was wondering if it is a by-product of bad tranny fluid.
Thanks,
2019yellow
Old Jun 10, 2024 | 02:08 PM
2019yellow's Avatar
2019yellow
7th Gear
Was this a recall or TSB problem.?
Old Jun 10, 2024 | 06:19 PM
Trebor's Avatar
Trebor
https://www.corvetteforum.com/forums...n-shudder.html
Transmission shudder A8.
Old Jun 10, 2024 | 08:47 PM
aklim's Avatar
aklim
Try your luck and find a dealer with one or two Corvette certified techs. Talk to them about the triple flush. After that, make an appointment with the appointment clerk aka Service Advisor.
Old Jun 11, 2024 | 08:14 AM
Tinkertech's Avatar
Tinkertech
You need to check the build date of the TRANSMISSION. (not the car build date).
There is a label on the trans that has the date.
If the trans was built after 2-01-19 then it has the new Mobil 1 Blue ATF.
If built before 2-01-19 you need to change the ATF fluid to the new Mobil 1 Blue label.
Old Jun 11, 2024 | 12:03 PM
kodpkd's Avatar
kodpkd
Does it "shudder" when shifting gears or when just driving? Probably would be good to change the fluid either way.
Old Jun 11, 2024 | 12:27 PM
2019yellow's Avatar
2019yellow
7th Gear
Thank you so much. I’ll look into your suggestion.
Old Jun 11, 2024 | 10:13 PM
C5FORFUN2's Avatar
C5FORFUN2
Question, is the new fluid actually blue or??
Old Jun 12, 2024 | 08:47 AM
Tinkertech's Avatar
Tinkertech
Its called 'BLUE' due to the fact that Mobil 1's bottle has a blue label on it.
The fluid is not blue in color.
I had all 3 types of fluid in my 17.
Original, don't know the color of the bottle.
Mobil 1 Black label bottle.
And now Mobil 1 Blue label bottle.
Old Jun 12, 2024 | 01:51 PM
Dcasole's Avatar
Dcasole
You say u just installed new tires that you inspected ....... don't discount the fact that tires, wheels or anything that rotates can mimic the shudder, I too had new tires put on my car, jumped on the highway to run it up to speed and instantly had what felt like shudder, even though I have V4 tuned out. it took to more tries at Road Force balancing before Discount got it right, the manager stated that there is a tolerance that they use but on the 2nd time they just kept at it till they got a " Bullseye" balance
If I did not just have the tires put on, I would have sworn that I had the shudder
Dave
Old Jun 13, 2024 | 11:38 PM
C5FORFUN2's Avatar
C5FORFUN2
Thanks, I assumed that, but it sure would be nice to be able to tell by the color if it was changed or not.
Old Jun 14, 2024 | 09:10 AM
Tinkertech's Avatar
Tinkertech
Maybe some one can tell by how it tastes?
Old Jun 14, 2024 | 10:10 AM
aklim's Avatar
aklim
To Transmission Fluid
