Performance Difference in Wheel Diameter Z51 to Base
Old Jun 19, 2024 | 10:11 AM
Smykster's Avatar
Smykster
Default Performance Difference in Wheel Diameter Z51 to Base
  • Front: 18-inch x 8.5-inch (Stingray) - Rear: 19-inch x 10-inch (Stingray)
  • Front: 19-inch x 8.5-inch (with Z51) - Rear: 20-inch x 10-inch (with Z51)
The top wheels are the base stingray sizes, the bottom set are Z51. The Z51 looks to increase the wheel diameter only, the width stays the same. Are there performance benefits with a larger diameter only? Seems like it would make sense on paper to go with the stingray base sizing to reduce unsprung weight and have better tire options (probably more comfortable too).
I have Z51 and I'm wondering why I'd want to keep the standard 19x20 sizing.
Old Jun 19, 2024 | 02:30 PM
CraigStu's Avatar
CraigStu
The OD of the tires is very similar 18/19 vs 19/20. So there isn't any perceptible change in gear ratio. My 19 base car came w/ the 19/20 sizes and I have swapped to 18/19. There is definitely a better ride w/ the smaller wheels since the tire section is taller. IMHO all this huge wheels, thin tires has a basis in race cars because, for a given tire OD, you can fit larger rotors/brakes. For a street car I think it is stupid.
Old Jun 19, 2024 | 04:35 PM
fuzzy03cls's Avatar
fuzzy03cls
19's came stock with 19/20. I would have preferred 20's or 19's all around actually. Z51 has 1" bigger front rotors which may have been a reason why they went to 19". And since GM wanted to keep the staggered, they moved 20's to the rear.
Old Jun 21, 2024 | 11:46 AM
Lux's Avatar
Lux
bigger rotors in the rear too.
Old Jun 21, 2024 | 09:40 PM
Dcasole's Avatar
Dcasole
nope , basr and Z51 are same size rear rotor , only the fronts are bigger
Dave
Old Jun 21, 2024 | 09:43 PM
Dcasole's Avatar
Dcasole
nope , base and Z51 are same size rear rotor , only the fronts are bigger
Dave
To Performance Difference in Wheel Diameter Z51 to Base
