C7 Running lean, air leak question
https://youtu.be/xl2pJu5mAVU?si=GcRHqSS4Pe5uPiP3
Only unmetered air downstream of the MAF sensor will affect the fuel trims.
And I’ll fix the exhaust leaks.
Lew has been around a long time and does know his stuff ... he is a good remote tuner and will help anybody but he is not on site , he told the guy he has vacuum leak ...he cant diagnose it from afar just like you cant , all u can do is offer suggestions which I am sure he did , he does not know the mechanical ablity of the people he is working with as he has 100's of customers most of which cant turn a screwdriver and if somebody messes with the wrong thing ... right away .... it would be his fault . Remember it's different when you are on a forum offering suggestions for free than when you are in business and getting paid for a service. He is getting paid to tune not to fix a vacuum leak
Dave
Dave
Sorry, but I don’t know who “Lew” is and what is capabilities are !!…all “Lew” said the car is running lean !!..he should have been able to tell OP how to diagnose these elevated fuel trims.
He can tell folks how to fix stuff but maybe he choses not to , he is not getting paid to diagnose ....he is getting paid to tune . It's no different than my remote tuner who told me I was not makeing enought boost ... I had to figure it out...
I am sure they do this because of the " you told me it was this ... " syndrome, i am also sure you have ran into this ...
Also you don't know what he told the OP ... you are assuming that he did not ... or did the OP even ask him what it was ?
Just don't assume 👍
Dave
Check the torque on you intake manifold bolts. They tend to loosen plus it’s quick and easy.
If both sides are leak, well obviously it must be a leaking air before the intake manifold plenum or near that area. However enough of a leak here will cause obvious idle air flow issues as I pointed out, making a leak obvious and uncontrollable engine idle rpm will rise too high.
Based on the lack of presented evidence that any particular oxygen sensor side was affected (if you had that info you did not share or it was left out) I rule out exhaust leaking issues assuming the oxygen sensors are indeed properly flipping 15mV to 1055mV (crossing the median at expected frequency indicating correct fuel control closed loop attempt)
Based on the lack of presented evidence of high idle speed, no high uncontrollable idle, this rules out significant intake manifold leaking.
Therefore the issue does not appear to be any leak related so far with presented information.
Next, I raise the concern or question of the term 'lean'. It is a very strange thing to say to somebody with an engine that needs to be tuned. I mean, if you bring me a fresh vehicle with a new engine and it needs tuning, it isn't going to run properly unless I tune it properly, by which point it will no longer run 'lean' unless I tune it to run lean. I guess what I'm saying is, the initial symptom presented as being 'lean' when the engine is untuned is highly irregular, as why would we expect a modified engine that requires tuning to not run lean or rich before such tuning has taken place.
This leads me to believe the engine has not been modified and a tune is simply being copied down to erase some potentially original tables with new settings. And that no significant modification has taken place, thus the tune is not 'needed' and the original tune is said to be intact and operational, which is the only way one could even assert that it was running 'lean' e.g. the tune is already done, finished, and we noticed that it is too lean for some reason. So why would the tune original be too lean if the engine has not been modified? Here are the possible reasons I can quickly think of
1. Dirty maf
2. clogged injectors (all of them? unlikely. But a few maybe)
3. dropping fuel pressure (did anybody mechanically measure this? Why isnt this being pointed out as a primary potential?)
4. Bad oxygen sensors (would be obvious, so not this)
5. wrong gasoline. You got some E15 or something it will lean out. The gas pump says it might have E15...
6. Misfire. Oxygen and unburnt fuel show up as a lean mixture. Could need maintenance...
6A-F is maintenance related, plugs, wires, balance test, oil test, compression test, etc... do the work to maintain the engine before you suspect "problems"
7. Engine air density changes. Extremely cold or driving down a mountain to more dense air will move trims around. Sometimes inexplicably.
8. Odd friction events causing increased load. It is possible to change engine load and populate less frequent regions of a fuel map due to new vehicle perceived mass, which would take trims for a walk learning this new load at some original operating RPM/velocity.
As a scientist and tuner I would be starting with engine health and misfire detection. plug inspection time. New gasoline. You start easy stuff first. Clean the maf. Try a different maf. Disable one cylinder at a time to watch how the a/f changes and the idle speed changes and engine noise quality changed. Compression test for balance and general health. Pressure test just to rule out tiny leaks if possible. Observe the behavior of the oxygen sensors flipping as they should. Observe fuel pressure using reliable mechanical gauge. Check the general health of the vehicle, brakes, rotating parts, bearings, bushings. Loud cars easily hide noises.
Once I determine the engine is healthy and setup properly for tuning and hardware has been updated maintained then you can see the injector pulse and engine breathing is rationale or not. If everything is rationale and all data looking good then you can tune the engine properly if it needs to be. There isn't any 'fixing a lean condition' before you tune - the engine either needs tuning, or it does not need tuning. It is either healthy or not. Being "lean" isn't a feasible or excusable concern.
I did not expect them to be so pricey. I need neighbors like you guys
