SC Heat Exchanger Leak?
I noticed my SC coolant reservoir was only about half full and when opening the fill port at the top of the engine it was bone dry. Not good... Figured I simply had a lot of air in the system and all I needed to do was refill with coolant and bleed the system of air. Well, I started slowly refilling the system from the top port with coolant. Everything was going well but it was taking a lot. I added about 6 cups and then noticed coolant leaking under the car. I can't see exactly where it's coming from but it's definitely centerline and in front of the radiator...the SC heat exchanger I'm guessing.
My question: Does there happen to be some type of overflow or something in that area that would allow fluid to leak out? My guess is no since this is a closed system but I gotta ask before I assume the heat exchanger itself is leaking. Are there any connections in that area that would leak as well?
I doubt there is a leak in the SC bricks since there is a high potential for the engine to hydrolock if a leak occurs in the bricks.
Bill
