3300 charger blinking orange indicator
Old Aug 20, 2024 | 06:15 PM
C7RDEX's Avatar
C7RDEX
Cruising
Default 3300 charger blinking orange indicator
Can anyone explain the blinking orange indicator light? Manual states that if both the orange indicator and green maintenance charge are blinking there could be a problem with the battery.
I don’t see in the manual where it’s talks about a blinking indicator and a steady maintenance charge.
File Type: mov
Old Aug 20, 2024 | 08:34 PM
Leroyt10's Avatar
Leroyt10
Make sure the 12V line has a good connection and clean. Also if you have an extension for the 12v line make sure that both sockets are tight as well
Old Aug 20, 2024 | 08:40 PM
hdrider1's Avatar
hdrider1
Like the last post said -- it means the charger is either not connected to the battery or to the 120v power source. Check your connections -- you sometimes need to rotate the plug for the Battery to get a good connection in the socket.
Old Aug 21, 2024 | 07:56 AM
rtv900's Avatar
rtv900
yep
just a problem with the cigarette lighter plug.
I used to get that all the time but now I leave more cord inside the trunk before I close it. I think if there's not enough slack it can slightly pull the connector and it makes a bad connection.
Once it trips out like that it will blink forever until you redo it
Old Aug 21, 2024 | 09:37 AM
C7RDEX's Avatar
C7RDEX
Cruising
thank you moving the vehicle connector around seems to have worked!! Appreciate it
To 3300 charger blinking orange indicator
