Bye bye torque tube
Old Aug 24, 2024 | 04:08 PM
Pktrusty's Avatar
Pktrusty
Default Bye bye torque tube
My torque tube went bye bye today. It didn’t snap but clearly gone. I had to limp it a mile home. What are the chances I damaged my clutch or crankshaft that the pilot bearing goes into? I have a manual obviously.
Old Aug 24, 2024 | 08:11 PM
Dcasole's Avatar
Dcasole
Probably zero since the input shaft on a manual floats in the clutch ....
Dave
Old Aug 26, 2024 | 04:59 AM
Lux's Avatar
Lux
You going with a 1 piece shaft replacement or going to just swap to billet/polyurethane couplers?
Old Aug 26, 2024 | 05:47 AM
Pktrusty's Avatar
Pktrusty
I am exploring options and open to suggestions. I know I sound like a cop out but I am going to see if anyone local will do it for a decent price as well. I was trying to sell my car due to heath reasons and I think this job maybe bigger that I can chew based off how I feel. I did all my motor work etc on jack stands and this would be the same.
I saw Weapon X sells the non bushing ones that are good for 1200 hp. Is it easier to do a fuel pump swap them too? I am eye balling a fore triple pump or one that will support more mods. Not sure if it is easier with the back half of the car apart lol.
Old Aug 26, 2024 | 11:17 AM
Lux's Avatar
Lux
Just go right to the source.
https://pstds.com/product/c7-corvett...coupler-delete
https://driveshaftshop.com/product-c...7-driveshafts/
^they also make a carbon fiber one
https://ecdriveline.com/products/201...41639597736116
As for the fuel pump if you want an easier install check out
https://www.mightymousesolutions.com...-fuel-tank-tap
Could use that and run an external inline pump or just go with DSX aux pump kit. How much power are you wanting to be able to support?
I don’t have experience with either but Snow Performance makes a drop in hat for double and triple pump setups
https://www.nitrousexpress.com/C7-Corvette-Fuel-Hat.asp
And Radium Engineering makes a single and double pump hat that has a really nice surge tank integrated.
https://www.radiumauto.com/14-19-Cor...ger-P3012.aspx
I’m a big fan of Radium parts especially their fuel pressure regulators.
Old Aug 26, 2024 | 01:08 PM
Pktrusty's Avatar
Pktrusty
I actually like that fuel tank cap. I can install that and run my pump setup somewhere else. I could size my pumps to get rid of my dsx low side.
I will take a look at the alternatives and go from there.
Old Aug 26, 2024 | 01:53 PM
Pktrusty's Avatar
Pktrusty
Does anyone know if there is a write up on removing the torque tube? I see one for rebuilding it.
Old Aug 26, 2024 | 02:06 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Just get yourself a 1 month subscription to Alldata DIY for $19.99 and it will go through the removal process.
Old Aug 26, 2024 | 02:09 PM
Pktrusty's Avatar
Pktrusty
To Bye bye torque tube
