ANC Active Noise Cancellation
Bose AudioPilot Noise
Compensation Technology (If
Equipped) : When turned on,
AudioPilot technology detects noise
and vehicle speed to continuously
adjust the audio signal so that music
will sound the same at a set volume
level. This feature is most effective
at lower radio volume settings
where background noise can affect
how well the music is being played.
See www.boseautomotive.com. This
feature can be turned on or off.
Press o BACK on the center stack
or touch the Back icon on the
infotainment display to go back to
the previous menu.
Ron
Disabling your C7's ANC requires either the dealer to do so or you can do it yourself with an after-market wiring harness that connects to audio-amplifier. That's how I did it several years ago.
There are some other CF posts about ANC, which will give you more information.
Regards,
Audio Pilot makes the volume louder when cabin noise is higher. You can turn Audio Pilot ON or Off in one of the audio setting menus.
Active Noise Cancellation, which cannot be turned-off in any menu, reduces cabin noise by cancelling low frequency noise sounds by playing the opposite noise signal (as picked-up by the 2 cabin microphones) through the low frequency speakers. Works like noise cancelling headphones. Lower frequency noise, from the engine and exhaust, is reduced by this system. The system is not effective for reducing higher frequency noise, like tire/road-noise. If you install an aftermarket amp, like for an added subwoofer, you must disable the Active Noise Cancellation by disconnecting the two cabin microphones.
