Do brake rotors unwarp?
Old Sep 19, 2024 | 10:01 AM
AnotherNorskie's Avatar
AnotherNorskie
Default Do brake rotors unwarp?
'14 C7 Stingray M7.
Once in a while when I apply the brakes the car shakes. "warped rotors". "build up of brake pad material".
But then the next time I hit the brakes, they're fine. A short while later, it shakes again. This can happen with minutes in between during normal city or highway drive. It seems to occur more frequently after spirited runs (and braking) but I don't have clear evidence of that.
If they were warped or had pad material buildup, wouldn't they always trigger shake?
I've lifted both ends and pulled/pushed on suspension parts and cannot detect anything loose. New front tires, rears are about two years old.
Ideas?
Old Sep 19, 2024 | 10:28 AM
JHundertmark's Avatar
JHundertmark
I doubt if rotors ever "unwarp", however, you mentioned brake pad material build up that can cause vibration similar to warped rotors. Depending on your stopping this could be removed & vibration reduced or eliminated. While not 100%, hard stopping can remove pad material.
Best wishes on your endeavor.
Old Sep 19, 2024 | 01:29 PM
bacord's Avatar
bacord
My chevy 2500 can remove some pad build up by doing a few hard stops but not eliminate it.
Old Sep 19, 2024 | 05:55 PM
Bill Dearborn's Avatar
Bill Dearborn
Pad build-up is not warping and sometimes the effects of pad deposits can seem to come and go. Pad deposits may not be as noticeable on relatively cool rotors but if you have just used the brakes hard enough to heat the rotors the pad deposits may have changed in friction sufficiently to make the brake pedal thump and may cause the steering wheel to vibrate. If the pad deposits get hot enough they can damage the surface of the rotor by making it harder where the deposit occurred and the hardened metal will have higher friction than other parts of the rotor thus making the spot hotter. When this happens the rotor needs to be replaced. The hardened spot in the rotor is also more susceptible to corrosion so you may start to a hole developing in the rotor surface.
Bill
Old Sep 20, 2024 | 08:29 AM
Tinkertech's Avatar
Tinkertech
If it was mine and really bothered me I would first 'sand' the rotors and pads and see if it helps.
Old Sep 20, 2024 | 09:30 AM
AnotherNorskie
If this is the case, that would explain why the shaking would vary with only a few minutes in between occurrences.
BTW it's not a 'thump' so much as a whole-car shaking; it isn't isolated to the steering wheel.
Is it possible to visually inspect for pad deposits?
Old Sep 20, 2024 | 10:20 AM
LT1GMC's Avatar
LT1GMC
FlexHone makes a nice rotary flat ball hone for use with a drill to deglaze rotors and it works great.
Old Sep 20, 2024 | 11:25 AM
Dcasole's Avatar
Dcasole
Thanks for posting ! Wish I knew this last week ... Just replaced all 4 rotors on my AMG because I could not remove the glaze and nobody would cut them because they were drilled . Did not know this type of hone existed
Dave
Old Sep 30, 2024 | 06:11 AM
Thanks for that info. Sure better than having to replace the rotors.
Old Sep 30, 2024 | 10:39 AM
kodpkd's Avatar
kodpkd
If it's something in the suspension you probably can't detect it by hand. I had a car with something loose and making noise in the front. I tried to move things even with a long crowbar, nothing moved, it turned out being a suspension link that was worn out.
Old Oct 4, 2024 | 06:36 PM
Avanti's Avatar
Avanti
For what it's worth, there is a spot on a nearby road close to a stoplight that would make you think it is rotors... until one experiences it happening even if the brakes are not applied there. It turns out, there's a subtle glitch in the road surface and the only place I've seen that does this.
Old Oct 9, 2024 | 05:53 PM
Lemans Blue's Avatar
Lemans Blue
The rotors can get very hot and glaze in certain areas, then the normal heat cycles can make it appear as warped. Time to replace them.
Also if anyone has ever turned rotors on a brake lathe you can hear the difference when the glazed area comes around, then by the time you get past the glazed area the rotors are now to thin so again just replace them they are consumables and not that expensive.
To Do brake rotors unwarp?
