Battery Distribution Fuse Block
Old Sep 27, 2024 | 03:16 AM
Ttrein76's Avatar
Ttrein76
Default Battery Distribution Fuse Block
I know this is a stretch, I haven't found anything in my searches BUT are there any aftermarket Fuse strips to replace this? I would like to get one with the unused 100amp with something larger. Would sure make my amp install that much cleaner.
Old Sep 27, 2024 | 03:37 PM
Lux's Avatar
Lux
I haven't seen anything to replace that block with but I would suggest running a wire to a bus bar or circuit breaker block depending on your amperage needs.
There is a lot of room under the hatch floor to keep it all hidden.
https://www.bluesea.com/products/199...Terminal_Studs
This will support up to 1000amps across the 8 terminals. That way you only have 1 wire going to the battery.
This will support up to 36 amps per terminal
https://www.bluesea.com/products/505...h_Negative_Bus
If you just need one connection
https://www.sonicelectronix.com/item...SGP901001.html
Old Sep 27, 2024 | 04:17 PM
Ttrein76's Avatar
Ttrein76
Thanks! I already have this: https://www.knukonceptz.com/product/...der-with-fuse/
So I do have a solution ready to go. I was just thinking it would be nice to have it "OEM" fused right at the battery, and since there already is a 100 Amp slot that *maybe* they have aftermarket swap outs. One less thing to mount and deal with. But NOT a big deal, just thought I would check!
Todd
To Battery Distribution Fuse Block
