Window Reindexing Help Needed!
Old Sep 30, 2024 | 09:20 PM
mig1980's Avatar
mig1980
Default Window Reindexing Help Needed!
Good day everyone. I wanted to start off by saying that I have searched online and on this forum for videos and articles about reindexing my windows. Nothing has worked.
I changed the battery today and here is what is occurring. Windows will go down auto but not up, the trunk won't open with the remote, and the windows won't drop and come back up when I open and close the doors.
I am also receiving multiple alerts on the dash about the convertible top and the anti theft (not sure what this is about).
I have tried closing the windows with the car started an in ACC mode. I have tried holding the switches up (all the way - second click and first click) for 5 to 15 seconds after the windows fully close. The same for down. I have tried doing this with the doors open and closed.
Any help on what specifically I need to do would be greatly appreciated!
Old Sep 30, 2024 | 09:34 PM
96GS#007's Avatar
96GS#007
https://www.corvetteforum.com/forums...g-windows.html
Old Sep 30, 2024 | 09:37 PM
96GS#007's Avatar
96GS#007
Sounds like what often happens when people break the little black wire that goes to the negative terminal and/or they haven't fully seated the fuse block.
You can see the little black wire by the negative terminal...
Old Sep 30, 2024 | 09:41 PM
Avanti's Avatar
Avanti
Do an "Advanced search" for battery replacement across the C7 Forums here. Changing batteries is a known cause of trouble because of the difficulty making adequate contact with all the needless mess connected to the positive battery post, especially the silly "L" plate. I'd suggest starting there, especially if you went by the online vids and PDFs that tell you (needlessly) to take that crap completely apart. If you are lucky, simply further tightening of all those nuts may solve your problem. I had trouble with mine a few months ago and posted my fix here, but when correct my '18 St'ray told me on the dash exactly how to index the windows. All the best!
Old Sep 30, 2024 | 09:51 PM
mig1980's Avatar
mig1980
Thank you all for the replies thus far. With respect to the black wire referenced, that is still intact. The connection block on top of the battery was seated correctly. It just clips on the battery nothing else is needed.
i checked all the bolts. Tightened securely.
Old Sep 30, 2024 | 10:04 PM
96GS#007's Avatar
96GS#007
What you may want to do is remove the negative battery cable. Then remove the nuts that seat the fuse block. Now put it back together again. These cars are funny like that sometimes and you just have to do the ol' "Cntrl / Alt / Delete" routine on them.
Many people remove all the nuts on the fuse block and if the leads aren't perfectly seated, stuff doesn't work right. The only two nuts that need to be removed are for the positive cable and the one that secures the assembly to the battery terminal.
Fuse block in question is below....
Old Sep 30, 2024 | 11:05 PM
mig1980's Avatar
mig1980
Here are the bolts I removed (circled in red). I will try tomorrow to remove them and reseat them.
I noticed that the windows do go down using the express click but they don't go up. This isn't related to reindexing the windows?
Old Sep 30, 2024 | 11:23 PM
96GS#007's Avatar
96GS#007
It can be but you listed a whole bunch of other stuff in your original post that also wasn't working correctly. If it worked fine before and the only thing that changed was the battery.......
Old Sep 30, 2024 | 11:35 PM
mig1980's Avatar
mig1980
I ask because I am just not sure if I am doing the reindexing wrong.
I have no clue what the theft deterent system message is all about.
I will try disconnecting and reconnecting the battery tomorrow but I assumed these issues were typical and needed to be reset after battery change.
Old Oct 1, 2024 | 07:43 AM
Tinkertech's Avatar
Tinkertech
Try it again in the morning before you disconnect anything.
Window and convertible top resetting procedure is in the manual.
Sometimes the modules get confused and take time to re- initialize.
If that does not work, disconnect the battery cables and reinstall them making sure they are seated completely and tight.
Old Oct 1, 2024 | 07:47 AM
69 L46 4 Speed's Avatar
69 L46 4 Speed
When I changed my battery last month, I had a Top Not Secure message even though I did not operate it. The trunk would not open either. I opened the top part way and resecured it. The message went away, the trunk opened and the windows indexed.
Old Oct 1, 2024 | 10:44 AM
DanA_F99_1977's Avatar
DanA_F99_1977
2024 C7 of the Year Finalist - Unmodified\
When I disconnected my battery to install new radio and interface modules, my trunk wouldn't open and I got the top not secure message. I lowered the top and put it back up and all worked fine after that. Didn't even check the windows so thay may have been something as well.
Old Oct 1, 2024 | 10:50 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
The FIRST thing you want to do is put a scan tool on the car to see if this may reveal any trouble codes that may give you some direction…if you don’t own one I would HIGHLY suggest to buy one…NOT a code reader as it will not you allow you to access body codes which you will need to…a code reader can not do this.
Old Oct 1, 2024 | 10:09 PM
mig1980's Avatar
mig1980
I wanted to follow up and thank everyone that replied. A special "Thank you" to @DanA_F99_1977
I started the car, lower the convertible top, raised it, and ran the reindexing on both windows. After that, all issues went away and I am back in business!
Old Oct 3, 2024 | 04:55 AM
Good news that all is well with the car. Time to enjoy a nice cruise.
To Window Reindexing Help Needed!
