Torque Tube questions
* From what I've read, there seems two main issues are causing Torque Tube failures, failing bearings which can cause driveshaft wobble with the rubber bushing rubbing and wearing inside the Torque Tube. And also the rubber bushings themselves cracking. Are these the two main causes of Torque Tube failures?
* Are Torque Tube failures to be expected eventually, or is this issue only occurring with a small percentage of C7's? And are there high mileage C7 owners out there who haven't experienced Torque Tube issues?
* I've heard that GM Service Centers will not rebuild a Torque Tube but instead will replace the entire Torque Tube/Drive Shaft assembly, with the cost being around $6k. is this correct?
* Is it correct that Torque Tube issues can occur on both automatic and standard shift C7's?
* I've read that GM Service Bulletins are out on this issue, and one states that changing the metal Stingray and GS Torque Tubes, to Carbon Fiber Z06 Torque Tubes solves the wear problems. Is this correct?
* I've read possible option is to replace the rubber bushings with metal bushings. I'm guessing GM initially used rubber bushings to absorb shock, so would switching to metal bushings be an unwise choice?
* And from what I've read, there is no way to inspect the condition of the rubber bushings without disassembling the Torque Tube (no inspection window on the torque tube). With the vehicle on a Lift is there any other way to check the condition of the Torque Tube bearings or bushings?
TIA
Rave
https://www.corvetteforum.com/forums...promising.html
https://www.corvetteforum.com/forums...ual-trans.html
2014 M7 85k ... no TT issues.
I'm guessing GM opt'ed to use rubber bushings to absorb gear shock during accelerating & deaccelerating, and shifting? And if that's the case, I wonder if changing to solid bushings has a negative impact on other drive train components? I can definitely understand where a minimum run out would beneficial, especially for the vibration of the M7 linkage and shifter.
Given the potential for out of tolerance TT run-out to cause expensive damage to the engine or transmission, catching the problem early sounds critical. Then the question becomes, do owners let GM replace defective components with the same components which puts the liability on GM, or do owners take a modified TT path and take on the potential liability themselves?
I wonder if the potential TT issues in the 5th, 6th, and 7th generation is one reason GM opt'ed to a rear engine design in the C8?
Rave
Rave
Rave
Is this a carbon TT price or metal? I paid around 2k to replace Z51 TT assy some years ago.
The most important question is: Will any Dealer, GM Service Center, Independent Shop or Performance Specialty Shop who will only replace TT with a new one make an extra effort to trouble shoot a new TT and measure the individual parts for excessive runout and then take steps to correct & optimize the TT? The correct answer is: Unlikely.
The next most important question is: Will any Independent Shop or Performance Specialty Shops who rebuilt TT make the extra effort to measure, correct and optimize the all the individual parts within the TT, also will they know about Buna-N o-rings vs. Viton o- rings, and will they know about Standard Bearings vs. Non-Contact Seal Bearings, all to give you the best chance of a TT that has less vibrations, noise and will last an extra-long time. The correct answer is: Yes/Maybe, but only if you the customer, the vette owner makes sure the shop is aware of the issues, parts upgrades and how to measure & optimize the TT and you are willing to pay for the extra efforts. I've mentioned many times about the parts having excessive runout, poor surface finishes, and very loose tolerances.
Too often we just trust that the OEM parts are the best regardless, but my findings prove otherwise, so "Trust But Verify"
TORQUE TUBE Blueprinting & Rebuild. First Results Look Very Promising - CorvetteForum - Chevrolet Corvette Forum Discussion
PART 4 Torque Tube Root Cause Failure Analysis Part 4 Manual Trans - CorvetteForum - Chevrolet Corvette Forum Discussion
Another point I've been meaning to bring up are the different noise when the TT is failing. When the O-ring loses grip on the bearing outside race you get the rattling growling sound as the bearing is flopping around in the housing bore. The clunking sound happens when the coupler has completely come apart, this noise happens mostly when you turn the engine off, the engine rotation stops fast but the drive shaft still has momentum and you hear the clunk when the coupler bolts hit the side of the flange. There is kind of a fail-safe mode that keeps the driveshaft from completely departing the input and output shafts, looking at the pictures you can see the output shaft stub that fits into a socket on the driveshaft, the input shaft is similar.
Look at the picture showing the shinny area of the bolt head, this was made by the bolt head slapping back and forward against the tri-lobe flange after complete failure of the coupler. So that might give a little comfort knowing this when you are a few hundred miles from home. Or it's race day and right after morning practice it clunks when you turn off the engine and you have the points lead and the last race of the season starts in two hours.
What would you do? Knowing what I know now I would roll the dice and go for it.
i got a bearing set sent to me by a service shop team who do Vettes everyday. I was surprised when I checked the bearing model spec only to find the bearings are not stabilized in temp above 120 degrees . The tube as you know can reach the mid 2oo's. obviously the bearings are going back but it does throw up a caution flag on several fronts.
what bearings and seals did you actually end up with.? how did it work out?
it doesn't seem like you used the anti-creep bearing with the rubber seals in the outer race.
I'm about to lower the rear assembly but will need to get the right parts to do the right job.
i'm already aiming at adding a heat shield from DEI on the tunnel cover to help reduce heat from the exhaust
now your comments are well received and have a lot of good info. Haven't remove the tube just yet but it’s close. Getting it checked by someone what their doing as well as the time to it may be the real challenge. I’m getting close to finding out what I’m up against.
thanks again for your diligence.
Tom
Tom
also has a /em type. The cost is quite different with or without the / em classification like nine ten times.
your photo shows the 6oo7 does have the /em but the 6008 doesn’t. Was there some reason
i know the EM indicates electric motor.
Bearing 6007LLBC3 also has a /em type. The cost is quite different with or without the / em classification like nine ten times.
I just checked Amazon the 6007LLB bearing is available for about $12.
