2016 Z06 no start.
Old Dec 9, 2024 | 06:04 PM
HT1663WB's Avatar
HT1663WB
Default 2016 Z06 no start.
Hopefully someone can help, 2016 Z06, M7, no start. Drove the car a couple weeks ago no issues. Went to start it yesterday and it would not start. Battery is good, code reader says link error. I tried plugging the SCT 4 tuner to return it to stock and the display says it cannot communicate. Tried reading vehicle info on the SCT and it displays vin blank and ecu not found.
also tells me to push the clutch in to start. Clutch is pushed in when this message appears. Any help would be greatly appreciated.
Thank you, Bill
Old Dec 9, 2024 | 06:26 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Don’t know what you mean by “link error” ??…do you mean a communication error ??…a communication issue can cause a no start…there are some things you can check with a DVOM on the CAN bus but I don’t know if you have one or know how to use it…you can’t communicate with the ECM so you may have to check power and grounds to that module…to be honest if it is a communication issue diagnosing these are way over the heads of dealerships and general repair shops.
Old Dec 9, 2024 | 06:52 PM
HT1663WB's Avatar
HT1663WB
Thank you for responding. I’m assuming the link error is a communication error.
Old Dec 9, 2024 | 07:08 PM
C5 Diag's Avatar
C5 Diag
Yes, most likely I’m assuming….best to use a factory or equivalent aftermarket scan tool to see what modules you can and can’t talk too…best bet is find an auto electric shop that uses a labscope which is helpful.
Old Dec 9, 2024 | 07:25 PM
C5 Diag's Avatar
C5 Diag
The ECM is on the High Speed Bus and as you can see there are 2 modules upstream of the ECM…if you are able try removing the connectors on the Power Steering and Electronic Brake Control modules and give them a shot of electrical contact cleaner and reinstall…if the 2 data lines have a poor connection you won’t be able to communicate with the ECM and the car won’t start…most of these issues I see are on modules on the outside of the car that are exposed to the elements…video so you can see what’s involved.
Old Dec 9, 2024 | 08:41 PM
RonC7's Avatar
RonC7
What is the voltage at the battery or fuse block or rear 12V outlet? How old is the battery? Low voltage / weak battery is the cause of many gremlins.
Can you charge the battery and try again?
Ron
Old Dec 9, 2024 | 08:46 PM
kodpkd's Avatar
kodpkd
Has the car been on a battery tender?
Old Dec 9, 2024 | 09:09 PM
HT1663WB's Avatar
HT1663WB
Battery was charged overnight, I even went out and purchased a new one. Same issue. Car is always on a battery tender.
Old Dec 9, 2024 | 09:53 PM
96GS#007's Avatar
96GS#007
What happens when you put it into accessory mode? Should be everything normal except the car not running.
What works? Can you move the seats?
Does the info screen go up/down when you push the button?
Interior lights come on?
What's the battery voltage when attempting to crank the car?
Is the little black ground wire that goes to the negative battery terminal attached and not broken?
Was the fuse block on the positive side of the battery properly installed?
Was the fuse block on the positive side of the battery properly seated?
Have you loosened everything up and tighten it again to be sure?
In accessory mode can you hear the parking brake operate if you set it/release it? Does the fob lock/unlock the doors? Did you pop the lid on the fuse box and look for anything suspect?
Did you try to start it by inserting the fob into the steering column?
If it's telling you to push in the clutch then usually the battery is bad or installed incorrectly or the clutch position sensor is bad/has moved...unless a rodent paid a visit to chow on some wires or you have headers and a wire bundle got torched, it's usually not anything unusual.
Old Dec 9, 2024 | 10:17 PM
HT1663WB's Avatar
HT1663WB
Everything works except no crank. The only thing I noticed is it doesn’t beep when I leave the fob in the car. I do not have headers and I checked for rodents no signs.
Old Dec 9, 2024 | 10:44 PM
RonC7's Avatar
RonC7
Do you hear a click under the hood? Can someone monitor the starter relay in the front fuse box? Or swap relays if there is another identical one? Might at least tell you if the car wants to start.
(the small black wire attached to the negative battery cable is a sensing wire used for charging, not a ground)
Ron
Old Dec 10, 2024 | 09:25 AM
kodpkd's Avatar
kodpkd
So it would seem it's an issue with the battery install. very common.
Old Dec 10, 2024 | 10:04 AM
HT1663WB's Avatar
HT1663WB
Issue was there prior to the battery install, no change with the new battery.
Old Dec 10, 2024 | 10:09 AM
kodpkd's Avatar
kodpkd
OOPS,, that's right.
Old Dec 10, 2024 | 11:32 AM
C5 Diag's Avatar
C5 Diag
Gentlemen, this is NOT a battery issue !!…OP can’t communicate with the engine computer so this is the critical piece of information…if he can communicate you turn down the other fork in the road and go towards battery, starter relay, battery cables and any other inputs in the starting system.
Old Dec 10, 2024 | 07:15 PM
HT1663WB's Avatar
HT1663WB
this describes it exactly
Old Dec 10, 2024 | 07:38 PM
C5 Diag's Avatar
C5 Diag
You can try Corvette Paramedics in Mt. Holly if you are needing a shop…that is the only Corvette Shop I know of in NJ.
To 2016 Z06 no start.
Old Dec 12, 2024 | 06:47 AM
HT1663WB's Avatar
HT1663WB
The Z06 is going to CSP in West Chester tomorrow. Unfortunately it’s being towed. I was scheduled to have some performance work done there anyway so off it goes. The shop assured me they would be able to figure it out. I will update the post when it’s fixed just in case anyone else has this issue.
Old Dec 12, 2024 | 08:12 AM
C5 Diag's Avatar
C5 Diag
Yes, let us know if they can figure it out !!
Old Dec 16, 2024 | 07:45 PM
HT1663WB's Avatar
HT1663WB
Problem ended up being a bad ECM.
