2019 LT4 - Coolant Cap Stuck
Old Dec 11, 2024 | 10:05 PM
VET4JDC's Avatar
VET4JDC
Default 2019 LT4 - Coolant Cap Stuck
As title says, my 2019 coolant reservoir cap will not come off. I can turn it counterclockwise as many as 1.5 to 2 times and then it stops. It's never been off before. What's the cause and how do I remove it?
Does it screw off or does it turn some and then lift off? If it lifts off, how much do I need to unscrew it before pulling up?
Old Dec 11, 2024 | 11:42 PM
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
It screws off.
Old Dec 12, 2024 | 09:06 AM
kodpkd's Avatar
kodpkd
I just had mine off, they can be very tight. keep turning it. I had to use a large channel lock. About 5 turns.
I just tried mine again, 5 turns.
I put a little grease on the O ring and now it comes off, easy peasy.
Mine also turned about 2 turns and got stuck, had to use my tool.
Old Dec 12, 2024 | 09:34 AM
rtv900's Avatar
rtv900
I thought I remember it turning first and then lifting off kind of like a traditional cap with those littler tangs on the sides
Old Dec 12, 2024 | 11:35 AM
kodpkd's Avatar
kodpkd
Nope.
Old Dec 12, 2024 | 07:49 PM
GOLD72's Avatar
GOLD72
Me too. Had to add coolant after 5 years and I needed channel locks to break it loose.
Old Dec 14, 2024 | 08:05 AM
RonC7's Avatar
RonC7
You should be changing Dexcool coolant at 5 years. 60% drinkable water / 40% Dex above -18 F. Use 50/50 if you expect to see temps below -18 F (yeah, right!).
Ron
Old Dec 18, 2024 | 11:06 PM
Thanks for the tip on removing the coolant cap. I have not taken mine loose so will keep this in mind when I do.
To 2019 LT4 - Coolant Cap Stuck
