Rt Rear Turn signal problem
Old Dec 29, 2024 | 02:01 PM
Cooter77's Avatar
Cooter77
Default Rt Rear Turn signal problem
2017 C7 Coupe: Rt turn signal operates normal for 2-3 flashes then goes hyper speed and car gets an indication rt turn signal is out and a partial functioning t/s light. . (Have Morimoto lights)
Note: I changed side markers from aftermarket back to original and only get 2-3 bulb operating on each marker. (changed side markers to oem because rt rear light went out at night and rt front TPS indicator was activated). Sorry, mis-spelled signal and could not change. Any help would be greatly appreciated.
Last edited by Cooter77; Dec 29, 2024 at 02:08 PM. Reason: mis=spelled signal in thread head
Old Dec 29, 2024 | 07:27 PM
kodpkd's Avatar
kodpkd
The OEM side marker lights only have 2 little bulbs. could there be a bad bulb in the rear light or maybe a bad connection.
Old Dec 29, 2024 | 09:47 PM
Cooter77's Avatar
Cooter77
Thank, I'll check connections.
To Rt Rear Turn signal problem
