Active Fuel Management Reccomedations
Old Jan 8, 2025 | 09:30 PM
RED92LT1's Avatar
RED92LT1
Default Active Fuel Management Reccomedations
Question, is it worth it, or necessary to eliminate AFM on the C7s.
I just purchased a 2017 Z06 with 18,000 miles and I am looking for advice and suggestions regarding AFM.
Many Thanks!
Brian
Old Jan 8, 2025 | 11:45 PM
aklim's Avatar
aklim
Define "eliminate"? Just having the ECM shut off the AFM is not too bad when you program it out. As a side effect, in an auto you can certainly get the transmission shift a little different and change the tip in for the throttle with the Diablo unit. From what I read, it can do it and revert if you have warranty issues and nobody will know any different.
If you want to eliminate it altogether by removing the weak lifters, it might take a cam swap. In which case you can add a little performance to the swap when you get the delete kit. Obviously that is a bit more money. If you plan on modifications, not a problem. This is the way to go. The speed shops I casually ask tell me that is the way to go since those are the lifters that more often than not fail. That of course opens up another whole can of worms. You plan to keep it for a while to get the most out of the money spent? Are you racing it?
Old Jan 9, 2025 | 07:09 AM
davanz's Avatar
davanz
Since 2016, in two C7's, I have been using the plug in device from Range Technology. Just leave it in the OBD socket under the lower dash, and it prevents the engine from going into 4 cylinder mode. The latest version also automatically shuts off when you kill the engine so there is no battery drain when the car is parked. It is not a "tune", and when unplugged, the car goes back to normal factory function. I used to unplug it from time to time when doing some highway cruising just to see if the car would indeed go back to activating AFM. I would find a level stretch of road where I could just cruise at about 60-70 MPH, and either hold a steady throttle or set the cruise control for a mile or so, and yes it would go into 4 cylinder mode. Then I would plug the unit back in, and under the same conditions, it would stay in V8 mode. You can go thru the fuel information screens to find the one which displays whether the engine is in 4 or 8 cylinder mode.
If you do this, my suggestion is to buy it directly from Range, rather than ebay, or Amazon. That way, you are going to get the latest version, rather than one which may have been setting on a warehouse shelf for a few years.
Old Jan 9, 2025 | 08:55 AM
RED92LT1's Avatar
RED92LT1
Thanks for the replies. So, I'm not planning on racing it ... kind of. It may see a couple of quarter mile runs, and maybe a few street races but for the most part I was wondering if defeating AFM was helpful, necessary or detrimental in the long run.
Thank you
Brian
Old Jan 9, 2025 | 10:35 AM
aklim's Avatar
aklim
Thank you
Brian
If you are manual, probably will be OK since it won't go into V4 unless you are in ECO mode. I don't like the dongle hanging out of the OBD2 port since I have kicked it out a few times. Also with emissions I have to take it out to get it into readiness by driving for a while.
Old Jan 9, 2025 | 01:08 PM
davanz's Avatar
davanz
The Range Technolgy unit plugs directly into the OBD receptacle, with no cords or dongle. Once in place you cannot see it unless you have your head down in the footwell.
Old Jan 9, 2025 | 03:08 PM
aklim's Avatar
aklim
It also sticks out of the port which is bad if you kick it. Having done this a couple of times, I figured it was a sign for me to get something else that was going to change the program and not use foolers on the ECM
Old Jan 9, 2025 | 03:21 PM
miami08VETTE's Avatar
miami08VETTE
If you have an M7 transmission, just don't use the ECO mode and it will never activate.
Old Jan 9, 2025 | 04:43 PM
calvins's Avatar
calvins
Oldtimer
Brian
Hey Brian, Sorry for the tangent but where in NW PA? Was born and raised in the Conneaut Lake/Meadville area. Left in '73
Old Jan 10, 2025 | 09:13 AM
Tinkertech's Avatar
Tinkertech
If you knock the Range out of the OBD port you stand a chance of damaging the connector.
Thats one reason I use a Diablo I3.
That OBD connector is a real PITA to replace.
Old Jan 10, 2025 | 10:04 AM
aklim's Avatar
aklim
Did it a couple of times. Wasn't sure if the next one will still be lucky. Call it a sign
Old Jan 11, 2025 | 09:42 AM
Tinkertech's Avatar
Tinkertech
The OBD plastic connectors are not that strong or made to have whatever constanly connected and reconnected over and over.
One reason I use a Diablo I3 to program AFM out.
You do you.
Old Jan 11, 2025 | 10:15 AM
RED92LT1's Avatar
RED92LT1
About 28 miles east of Meadville in Franklin, we've been to Conneaut Lake several times ... remember the amusement park. We've been here since 1977, moved here from Reading, PA.
Brian
Old Jan 11, 2025 | 10:22 AM
96GS#007's Avatar
96GS#007
To be clear, the Range device or any other software just keeps the PCM from entering AFM mode. What fails are the AFM lifters. Those are still in the car in all their glory. One can debate if the Range device reduces the possibility of failure but the weak link is still in the engine.
Old Jan 11, 2025 | 01:01 PM
stevettec7's Avatar
stevettec7
I had been using a Range AFM for the majority of the 80k+ miles on my '15. I would occasionally pull it to allow the AFM lifters to be exercised. Sadly, the last time I pulled it on my way to the dealer for an oil change, one of those lifters failed. It was a very costly event.
Now I have it disabled in the ECU firmware with the Diablo i3. As long as the signal to activate the AFM solenoids remains disabled, those lifters will never activate again. Sure, there's no guarantee something won't fail in the future, but short of doing a full AFM delete, I feel this is the best option.
Oh, and I would advocate AGAINST the use of a Range disabler. The risk of possible failure of the device or loss of connection by either poor connectivity or accidentally hitting it while getting in/out of the vehicle is too high.
Of course this could be debated 'til the cows come home. Just my opinion based on experience.
Old Jan 11, 2025 | 04:15 PM
aklim's Avatar
aklim
I need to exercise. You need to exercise. I don't think AFM lifters need exercise. I've also pulled it after a long inactivity period because I kicked it a couple of times, I think it is just coincidence.
Some have said so, others have said it is like disabling it with the Range device except you can tweak a few more parameters. Either way, no guarantee it does anything. Only way to be sure is a cam swap.
I'm more worried about changing the OBD2 port. Any idea how big a PITA that can be?
Old Jan 12, 2025 | 10:06 AM
Tinkertech's Avatar
Tinkertech
If you break the OBD port connector your only choices would be:
Add a pigtail connector, not the cleanest route.
Find a replacement plastic shell and swap the wires to the new connector.
Lesson learned here is don't take chances in breaking the connector.
To Active Fuel Management Reccomedations
Old Jan 12, 2025 | 10:31 AM
aklim's Avatar
aklim
Nobody ever kicks the unit until they do. Fortunately for me, 2 times was lucky and I wasn't going to see if the 3rd was too.
Old Jan 13, 2025 | 10:19 AM
Tinkertech's Avatar
Tinkertech
Just spitballing here:
Wouldn't it be nice, if possible, if some company engineered and manufactured lifters of the proper length that they could be just dropped in the AFM lifter holes without a cam change thus eliminating the dual action of the AFM lifters and all their issues? These lifters would act like the V8 mode was always engaged.
Kind a like a lifter and cam change but only the the lifters would be replaced.
These lifters would operate just like normal lifters but designed for only the AFM holes.
Not really sure if this idea is even feasible.
I'm on my first cup of coffee of the day...........
Old Jan 13, 2025 | 12:52 PM
emfollin's Avatar
emfollin
Labor would still be intensive as you must remove the heads to replace lifters. I don’t think too many people would be willing to pay that labor and not do more then just remove AFM lifters.
