Check Engine Light - Tuned car
Old Jan 24, 2025 | 11:53 PM
Waelaburezeq's Avatar
Waelaburezeq
Default Check Engine Light - Tuned car
Hey folks,
I recently purchased a 2019 GS which seems to be tuned, it had modified headers as well BUT I can see the original air filter. The car has a check engine light, and few codes that i believe they are related. On top of that I didn't see V4 mode activated so it might all be related. Here are the codes I am getting:
---------------------------P0011 [0x0011]Camshaft position (CMP), intake/left/front, bank 1 - timing over-advanced/system performance"A" Camshaft Position - Timing Over-Advanced or System PerformanceStatus: Confirmed
----------------------------P26C8 [0x26C8]Status: Confirmed
----------------------------P2535 [0x2535]Ignition switch, ON/start position - circuit highIgnition Switch Run/Start Position Circuit HighStatus: Confirmed
----------------------------P2534 [0x2534]Ignition switch, ON/start position - circuit lowIgnition Switch Run/Start Position Circuit LowStatus: Confirmed
----------------------------P0056 [0x0056]Heated oxygen sensor (HO2S) 2, bank 2, heater control - circuit malfunctionHO2S Heater Control CircuitStatus: Pending
----------------------------P0057 [0x0057]Heated oxygen sensor (HO2S) 2, bank 2, heater control - heater circuit lowHO2S Heater Control Circuit LowStatus: Pending
----------------------------P0161 [0x0161]Heated oxygen sensor (HO2S) 2, bank 2, heater control - circuit malfunctionO2 Sensor Heater CircuitStatus: Pending
Old Jan 25, 2025 | 09:09 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Didn’t you post the same issue a few days ago ??….can’t have duplicates so do you want this one deleted ??…other post you said you have a 2019 ??…beyond the advice we have already given you that’s all we have for now….there is no silver bullet for any issue you may be having.
Old Jan 25, 2025 | 10:01 AM
Waelaburezeq
Thank you mate for your reply, I posted the other one in a wrong forum and I couldn't delete it. This post also has more details. Thanks for your help
Old Jan 25, 2025 | 11:02 AM
C5 Diag's Avatar
C5 Diag
Your other post is deleted and as I mentioned check your battery and engine oil…there is not going to be a 100% accurate diagnosis on this Forum unfortunately !!
Old Jan 26, 2025 | 08:43 AM
Tinkertech's Avatar
Tinkertech
All your codes point to the bank 2 and sensor 2 O2 heater.
I see only two possibilities, one easy the other not.
Bank 2 sensor 2, O2 sensor heater is malfunctioning. Check all of the wiring going to this this O2 sensor, measure this O2 sensors resistance at the PCM, O2 connector disconnected from the PCM of course. Check the connectors for damage of course.
Now you need a scanner.
A bad PCM.
Old Jan 27, 2025 | 04:08 AM
Waelaburezeq
hey folks,
so I was "luckly" be able to reach to the old owner, idenfitied the garage who did his window tent and I went their where they called him ))).
The car has the following modifications, BUT NOT AIR FILTER NEITHER A TUNE
- Upgraded headers
- Upgraded camshaft
- Upgraded downpipe
- Removed catalytic converter
I am afraid that I must tune the car, and install an air filter (the current one is the STOCK!!). What are your thoughts on Air filter and tune ?
Old Jan 27, 2025 | 09:12 AM
Turtletron's Avatar
Turtletron
Filter isn't a big deal. Tune is a necessity.
Old Jan 27, 2025 | 09:59 AM
Waelaburezeq
Should I:
- keep the current air filter and Tune
- change only the air filter (options are Attack Blue, BMS and K&N) And Tune
- Change air intake and Tune
I have been reading much about it, no bullet proof decision is there yet
Old Jan 28, 2025 | 02:45 PM
Travlee's Avatar
Travlee
with lth, cam and no cats... def need a tune
Old Jan 29, 2025 | 11:05 AM
88redconvert's Avatar
88redconvert
hey folks,
- Upgraded headers
- Upgraded camshaft
- Upgraded downpipe
With those mods, you definitely need a tune.
Old Jan 29, 2025 | 02:26 PM
Waelaburezeq
how about the air filter? Do I have to go with full intake? Or upgraded filter is enough
Old Jan 30, 2025 | 12:03 AM
C5FORFUN2's Avatar
C5FORFUN2
Filter is enough. CAI's are just cosmetic in most cases.
Old Jan 30, 2025 | 02:35 AM
Waelaburezeq
thx mate
Old Jan 30, 2025 | 09:31 AM
Waelaburezeq
Folks,
do you really trust custom tune? Is there anu recommended tune i have to go with?
Old Jan 30, 2025 | 09:32 AM
Waelaburezeq
thank you, I would appreciate if you change the title to (Recommended Tune)
Old Jan 30, 2025 | 09:44 AM
Travlee's Avatar
Travlee
Folks,
dyno tune would be the best, then they can tweak it to your specific car
Old Jan 30, 2025 | 10:18 AM
Waelaburezeq
indeed, but tweaking on dyno tune is then a custom tune. Isn't?
To Check Engine Light - Tuned car
Old Jan 30, 2025 | 11:08 AM
Travlee's Avatar
Travlee
yes...a canned tune could work, but i personally wouldnt do it
Old Jan 30, 2025 | 11:10 AM
Waelaburezeq
After all the changes the previous owner did, I am afraid I am forced to do tunning? - Custom Headers- Camshaft - downpipe- removed catalytic converters
Old Jan 30, 2025 | 11:13 AM
Travlee's Avatar
Travlee
yes...
