C7 error Code U0428-4B
Old Feb 1, 2025 | 02:54 AM
jasonh5288's Avatar
jasonh5288
1st Gear
Default C7 error Code U0428-4B
I just change my clock spring and is showing this error code U0428-4B Steering Wheel angle sensor calibration not learned. I use foxwell computer to reset or lean it. But it is showing rejected by control module even when I change a computer to do the process and still showing rejected. Does anyone know how to fix it?
Old Feb 2, 2025 | 04:29 PM
Bill Dearborn's Avatar
Bill Dearborn
The steering angle sensor module is attached to the clock spring module. You may need to remove the steering wheel to see if there is a problem with the angle sensor's electrical connections.
Bill
