Need a spring compressor for changing transmission mounts?
Old Feb 3, 2025 | 09:16 AM
Darth_Helmet's Avatar
Darth_Helmet
3rd Gear
Default Need a spring compressor for changing transmission mounts?
Hi all first post here. I have a bad transmission mount on my 2014 c7 base with the m7 trans. One of the steps in the procedure to change the mount is to use a GM tool J-33432-b which appears to be a leaf spring compressor and is over $1000. My question is if there is a way to avoid using this speciality tool? I have dug around in the forums and YouTube and there isn’t much info about replacing trans mounts.
Old Feb 3, 2025 | 11:18 AM
sammy burks's Avatar
sammy burks
Active Streak: 90 Days
there is no transmission mounts on the C7 they are located on the differential 3 bolts holds it in. will need to lower the cradle down. no speciality tools need just jacks & hand tools
Old Feb 3, 2025 | 06:06 PM
Bill Dearborn's Avatar
Bill Dearborn
Sadly, the Factory Service Manual disagrees with you. There are only engine and transmission mounts. If the FSM replacement procedure is followed a leaf spring compressor is required to replace the transmission mount.
However, that doesn't mean the GM tool has to be used. I have seen workarounds using various hydraulic jacks to remove the spring pressure from the lower control arms so the cradle can be dropped.
Bill
Old Feb 3, 2025 | 07:11 PM
Darth_Helmet
3rd Gear
Bill
Bill do you have any detail on how to remove the spring pressure using jacks instead of the gm tool?
To Need a spring compressor for changing transmission mounts?
