2019 Z06 Climate control not changing
Old Feb 4, 2025 | 11:44 PM
Suspense84's Avatar
Suspense84
Default 2019 Z06 Climate control not changing
Hey guys. Recently I turned my car on to take in for an oil change and I noticed the fan speed just stays on. I can’t change the fan speed but everything else is working. I’m able to change the temperature, AC, defroster are all working. Anyone have this issue ? The dials on the fan speed don’t even light up. I tried the unplugging the blower motor and plugging it back in without success.
Old Feb 5, 2025 | 11:40 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
First thing to do is to see if there are any trouble codes present...AC trouble codes are "B" or Body codes and will not be able to be read by a "Code Reader"...you will need a factory level or equivalent scan tool...with these scan tools you can look at 'inputs and outputs"...when you adjust fan speed and the scan tool does not show an increase or decrease in fan speed you have an input problem...you can command the blower motor to increase or decrease using output controls...there is a blower control module that controls the fan....either way you will need to check for any Body codes....there is a 40 amp fuse you can check...maybe it's blown !!
Old Feb 5, 2025 | 11:49 AM
C5 Diag's Avatar
C5 Diag
Fuse is # 3 upper left !!
Old Apr 5, 2025 | 11:34 AM
Suspense84's Avatar
Suspense84
Tried both these methods without success. Anyone else have any other ideas ? Thanks
Old Apr 5, 2025 | 01:15 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
During your oil change, did you happen to bring this concern to your dealer's attention? They will be your primary source for assistance if you're unable to correct it on your own. Our team is an email away at socialmedia@gm.com, if you'd like help setting up appointment arrangements at your preferred dealership. Just please include your Username and Forum title in the subject line when you send that message.
Old Apr 26, 2025 | 09:33 AM
Suspense84's Avatar
Suspense84
Respectfully I was trying to avoid the dealership because I know they are going to charge me an arm and leg just to find the issue
Old Apr 26, 2025 | 09:41 AM
C5 Diag's Avatar
C5 Diag
If you still haven’t resolved your issue I highly suggest you find an auto electric shop in your area and take the car there.
To 2019 Z06 Climate control not changing
