C7 starter staying engaged?
Old Feb 10, 2025 | 12:49 AM
alexave7's Avatar
alexave7
4th Gear
Default C7 starter staying engaged?
Hey second post here on the forums so if I’m doing this wrong please be patient with me. The starter on my 2014 c7 stingray went bad a few weeks back. When I ordered the new one it was an original gm starter but when I got everything buttoned up and turned on the car it sounded almost as if the starter was still engaged. I took the starter to get tested at a local spot I trusted and everything was good on the test. I was given a remanufactured starter identical to see if I had any luck and still the same problem I will attach a video of the sound it’s making and hopefully someone can point me in the right direction as of now I swapped out the starter relay in the fuse box with a different one in the fuse box and still had the same problem. Thank you for taking the time to read and help.
File Type: mov
File Type: mov
Old Feb 10, 2025 | 06:28 AM
69 L46 4 Speed's Avatar
69 L46 4 Speed
It sounds like you may need to add a shim. The starter is engaging the flywheel and there is not enough clearance to allow it to disengage. The starter will burn up if this isn't corrected quickly.
Old Feb 10, 2025 | 08:15 AM
Tinkertech's Avatar
Tinkertech
Old Feb 10, 2025 | 12:58 PM
kodpkd's Avatar
kodpkd
Sounds like it's rubbing against the fly wheel. If it were really engaged, I think it would be destroyed. If you can see the fly wheel, look for scrape marks.
Old Feb 11, 2025 | 08:33 AM
Tinkertech's Avatar
Tinkertech
Rubbing or engaged, the starter needs to be shimmed to the proper distance from the flywheel.
Worst case, you'll start breaking teeth off the flywheel or destroy the starter or both.
To C7 starter staying engaged?
