Diagnosis
Starting off the drive from neutral to first gear. I ease off the clutch until the biting point and at this point I usually blip the throttle to give it a bit of gas and start rolling. Usually the tiniest blip would rev the car loud as it should but lately the car would sound low/muffled or won’t sound off at all. The rpm’s would still go up tho. So now with this issue, I’m forced to add more pressure to the throttle than before to just get the car rolling. There had even been times where I’m blipping the throttle bit by bit, rpm’s go up and the car doesn’t want to move and if finally started moving after my foot was basically halfway down the accelerator. Down shifting is another issue but is still connected with this throttle issue. Anytime I blip the throttle to downshift it sounds like it cuts itself off which then leads me to lug the car. Usually when I blip it, it would do a AHHHHHH loud reving sound like normal but now it would go AHH—- and cuts off. The car doing that forces me to strictly drive with rev match on cuz I don’t wanna ruin the clutch trying to drive it normally with that issue still occurring. But even with rev match on it still does that half *** rev sound when downshifting. The car has an aftermarket intake, long tube headers, tsp xpipe, and a corsa exhaust. It shouldn’t be sounding so low like it is now. It sounds almost stock when idling. Recently got it tuned to see if that would fix the problem but nothing changed minus all the codes being wiped. Previous owner installed all those aftermarket parts and has had the car with the check engine light on the whole time. I got it from the dealership that way and left it as is cuz it was driving fine without the need of the tune. This issue started happening a couple weeks back and I’ve owned the car since October 2024. Tuning it didn’t help and my tuner/mechanic doesn’t find any issue other than the car running lean. Idk how it’s running lean but any info would help
And, how can you beat free?
There are a few Corvette specialty shop around the Los Angeles area. These https://americanheritageperformance.com/ charge dealer prices or more, but there reputation is 5*****. Very knowledgeable and very professional work. Worth it in my opinion.
