Remote Tuning Recommendations
Old Mar 5, 2025 | 11:24 PM
Neorift's Avatar
Neorift
Default Remote Tuning Recommendations
I'm finishing up my cam install this weekend and am wanting to find someone reputable with Gen V LT1's to do the tune remotely. The tune doesn't have to be done this week, would just like to get on the schedule.
I have seen people offering tuning here in the past but I am not sure who is still doing it and a forum search didn't really offer much.
Old Mar 6, 2025 | 08:27 AM
C7_Nighthaven's Avatar
C7_Nighthaven
Cruising
Gwatney Performance for sure
Old Mar 6, 2025 | 01:24 PM
9sec's Avatar
9sec
gpi or internets ninja on here
Old Mar 6, 2025 | 02:33 PM
96GS#007's Avatar
96GS#007
Internets Ninja posts on here
Greg Huggins is over on the HP Tuners forum and is also fantastic.
For whoever you choose, you'll need a wideband o2 sensor installed in order to tune WOT.
Old Mar 6, 2025 | 03:29 PM
Neorift's Avatar
Neorift
That reminds me; can I run the WB sensor in the factory bung? Trying to avoid welding a new one since space is limited upstream from the cats.
Old Mar 7, 2025 | 09:42 PM
96GS#007's Avatar
96GS#007
I don't think you can since you need the fuel trim data from that o2 sensor for idle, part throttle, and cruise.
You can always put a spare bung on the side of one of the pipes where the tunnel widens. Then just tape the wire to the bottom of the car and run it inside the driver's side door to the gauge. You don't need a permanent installation, just enough to get you tuned. Many will tune everything except WOT without a wideband so ask whoever you pick. Depends on the level of perfection that's desired.
For WOT it'd be better on a dyno and they can use a wide-band that sticks in the tailpipe if you have no cats. I'd expect that's what a remote tuner may want for WOT. It's hard to do 4th gear WOT pulls on the street to 150mph+ to get good data.
Bottom line, talk to a couple Tuners and ask them what they want. Like anything, they all have a process they follow that works for them.
Pay no attention to the **** location of the OEM sensor on mine. That's being rectified. That aside, you can see where the wb bung is located:
Old Mar 9, 2025 | 08:21 AM
Dcasole's Avatar
Dcasole
@96GS#007 , do you have any issue with your O2 sensors because they are not "Angled" down ?
Dave
Old Mar 9, 2025 | 09:53 AM
2001PewterWS6's Avatar
2001PewterWS6
Internets Ninja - Jason@Snackbartuning.com
Old Mar 9, 2025 | 01:41 PM
96GS#007's Avatar
96GS#007
Dave
The sensors have always worked fine in that orientation. The new ones will be further forward (~4 inches) and at ~10 o'clock position (drivers side) ~2 o'clock position (passenger side) with the new setup. That's to eliminate heat shield interference and move the bullet cats forward so the tunnel plate fits without spacers.
I know in years gone by the concern was about condensation on the tip of the sensor but those sensor weren't heated. Not sure how much that applies these days since the sensors are heated. Maybe if I was in an area like FL with brutal humidity?
To Remote Tuning Recommendations
