TPMS Sensors
Old Mar 6, 2025 | 05:46 PM
17 Z06/Z07's Avatar
17 Z06/Z07
Default TPMS Sensors
Mounting some new wheels and tires and would like to know a good source for TPMS sensors.
Old Mar 6, 2025 | 08:13 PM
kodpkd's Avatar
kodpkd
I am reluctant to recommend these,,,,,, but I did install these on my new wheels about 3 months ago. So far they work just fine. I figured if they didn't work, I could replace them myself. If you don't think you could do this, it may be to big of risk. It would probably cost $200 for a tire shop to change them. When I looked at them, they did look just like the OEM ones. All of the TPMS's are made in China. Let us know how it goes.
Amazon Amazon
Old Mar 6, 2025 | 08:38 PM
17 Z06/Z07's Avatar
17 Z06/Z07
Thanks kodpkd, I had them saved,lol..... They are exact duplicates of my TPMS and the ones in my 2017 are still working, lol. I see a pretty big price difference on these guys so thought I would ask.
Wonder where these are made? Why are they $42.xx for just one?
GM Tire Pressure Monitor Sensor for C7 Stingray, Grand Sport, Z06 and ZR1 Corvette
Genuine GM tire pressure monitor sensors for 2014-2019 C7 Stingray, Grand Sport, Z06 and ZR1 Corvette
$42.25
Old Mar 6, 2025 | 08:57 PM
kodpkd's Avatar
kodpkd
I got black wheels and love them. I did have to paint the valve stems so they matched.
Old Mar 6, 2025 | 09:11 PM
kodpkd's Avatar
kodpkd
$42.25
YEP,,,,, GM. They are all made in China. I thought of just using my OEM TPMS, but I figured there was an equal chance the 11 year old ones would failing, as the new ones.
Old Mar 6, 2025 | 09:42 PM
RacerRik's Avatar
RacerRik
Do not buy the Amazon ones. In two years or less they will be dead - ask me how I know....
Instead go to Rock Auto and get the Schrader 20223 sensors for around $20 each. I talked to an engineer at Schrader before purchasing these. He explained it is the exact same sensor they produce for GM under the AC Delco brand. It has a different part number because that is the only way Schrader can sell it in the aftermarket business. I have used the 20223 sensors multiple times and they look and work exactly the same as the OEM sensors but are less expensive. Have had a set in my car for 5 years with no problems.
Old Mar 6, 2025 | 09:50 PM
dlsmith82's Avatar
dlsmith82
Are you going to do the mount yourself at home?
Old Mar 6, 2025 | 10:03 PM
RacerRik's Avatar
RacerRik
Unless you have a tire machine, this is not a do it yourself type job. You have to break the bead of the tire on the outside edge and the safe way to do that is with a bead breaker on the tire machine. Once the bead is broken, you can compress the tire enough to replace the sensor, but it requires serious force. You will not do it without tools. Run flat sidewalls (and competition tires) are seriously stiff. You can stand on the sidewall and it will barely move. I use up to five 600 LB force bar clamps to compress the sidewall of the tire.
Old Mar 6, 2025 | 10:14 PM
17 Z06/Z07's Avatar
17 Z06/Z07
No ,I will bring my new tires, wheels and TPMS to an installer that has a new tire machine that can handle these bigger wheels.
@Racerrik thanks for that info.
Old Mar 6, 2025 | 10:28 PM
kodpkd's Avatar
kodpkd
That's what I did. I didn't want the tire shop to remove and install the wheels on my car. I removed them from my car and had them just switch the tires to the new wheels. I installed the new TPMS on the new wheels. I talked to the installer and he assured me he wouldn't scratch the new wheels.
Old Mar 6, 2025 | 11:59 PM
RacerRik's Avatar
RacerRik
So if / when your Amazon sensors fail, will you replace them yourself without going to the tire shop? If so, how will you do that? I think others might be interested if you have a good method of doing this DIY. I have done it myself many times, but I do have a tire machine and super strong bar clamps so my methods won't really help anyone who does not have those tools.
By the way - I commend you for not letting the tire shop work on your car. The reason I bought my tire machine and a balancer is because of so many times the tire shops have damaged my wheels, my new tires and my cars. Most of those places have employees that don't give a damn if the wheels on your car cost more than the car they drive. They probably damage stuff on purpose out of jealousy.
Old Mar 7, 2025 | 08:53 AM
kodpkd's Avatar
kodpkd
Crossing my fingers,,, we will see how long they last. I would love to know where all of the TPMS's are made. It wouldn't surprise me if they are all the same. I looked at the plastic housing on the ones I got and compared them to the OEM ones, you could see molding marks in the plastic that were exactly the same. Looking at all the different suppliers on Rock Auto, they also look the same. There are a few DIY's on changing them on YouTube. I don't have run flats so maybe it is doable.
Old Mar 7, 2025 | 01:43 PM
dlsmith82's Avatar
dlsmith82
I had my new tires mounted at a local speed shop and they supplied the correct TPMS stems. just sayin...
Old Mar 7, 2025 | 01:58 PM
kodpkd's Avatar
kodpkd
Do you know which ones they installed? How much did they charge you for them?
Old Mar 7, 2025 | 02:50 PM
dlsmith82's Avatar
dlsmith82
Sorry, I don't. They obviously had to be compatible with my 2016 Z51.They charged me $35 each.
Old Mar 7, 2025 | 03:04 PM
RacerRik's Avatar
RacerRik
The cheap Amazon ones were fully compatible with my 2018 C7 and worked fine but only for about two years. They looked nearly identical to the OEM AC Delco ones.
Old Mar 7, 2025 | 03:20 PM
17 Z06/Z07's Avatar
17 Z06/Z07
Ordered the Schrader TPMS RR recommended paid 101.00 with tax and shipping.
To TPMS Sensors
Old Mar 7, 2025 | 05:31 PM
GOLD72's Avatar
GOLD72
I have never an issue with Discount Tire providing the correct TPMS units for my various C6 vettes and a 2010 caddie CTS when the original factory units quit.
Old Mar 8, 2025 | 10:20 PM
PJO's Avatar
PJO
Veteran: Marine Corps
OEM on Amazon.
Amazon Amazon
Old Mar 12, 2025 | 06:37 AM
That sounds like a great deal for replacement TPS. I’ll keep that in mind.
